wrinkled covering
I'm Getting wrinkles on my plane Is that Normal?
Is there a way to fix this? :confused: |
wrinkled covering
it happens but is an easy fix , go over the plane with a heat gun and it will look like new
wrinkled covering
You can usually remove the wrinkles with a heat gun pretty easily, easy does it, dont hold the heat still,or youll burn a hole quickly.
its not unusual to develop a few wrinkles. |
wrinkled covering
Originally posted by mnc it happens but is an easy fix , go over the plane with a heat gun and it will look like new Now I can paint it any color I want. Also I just finished a wing. The covering is all balsa (super thin and sanded down with 0000 steelwool) Came out beautiful :) |
Thanks Guys!
1 Attachment(s)
Thank you for the info.
I'll try this tonight. |
wrinkled covering
Heat gun or iron will re-shrink the covering generally,the gun can cover to much of an area sometimes,if the covering is some hong kong phooey type it may not stretch very well,so test a small area,and increase the heat slowly.As the humidity changes so does the wood,it expands and contracts.
TerrellFlyer,
1 Attachment(s)
Originally posted by TerrellFlyer Heat gun or iron will re-shrink the covering generally,the gun can cover to much of an area sometimes,if the covering is some hong kong phooey type it may not stretch very well,so test a small area,and increase the heat slowly.As the humidity changes so does the wood,it expands and contracts. I get pockets in the covering. Question-1: what is the best heat gun I can buy? Should I buy one at Home Depot or are those different than the ones at a hobby store. Question-2: What do you recomend for covering? Are there different thicknesses in coverings? |
wrinkled covering
Buy the heat gun at a r/c hobby store,as far as an iron I use 21st Century, it has a nice shoe and a temp gage that works.Oh boy.Ask 5 people which is the best and you'll probably get 7 different answers,think all coverings have some good and some bad,I use Ultracote the most,then next MonoKote.
Thanks T F
1 Attachment(s)
Originally posted by TerrellFlyer Buy the heat gun at a r/c hobby store,as far as an iron I use 21st Century, it has a nice shoe and a temp gage that works.Oh boy.Ask 5 people which is the best and you'll probably get 7 different answers,think all coverings have some good and some bad,I use Ultracote the most,then next MonoKote. |
| All times are GMT -8. The time now is 02:59 AM. |
