RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Which will work better in Florida? (https://www.rcuniverse.com/forum/beginners-85/4618120-will-work-better-florida.html)
cjposada 08-13-2006 04:43 PM
What are we better off here in Florida as far as glow plugs? A3 or #8 OS or what?
skeeter1255 08-13-2006 05:15 PM
RE: Which will work better in Florida?
hey sorry I can not answer your question but since u live in fl and have a nitro plane u must fly in a field..... were are the fields u go to fly at I can not seem to find any around here!
2slow2matter 08-13-2006 07:22 PM
The choice of glow plug is related to the engine you are using, not to the climate it's being used in. Read the manual. When all else fails, go for the #8 if it's a two stroke. Four strokes need hot plugs--OS F, or H9 super plug for example...
cjposada 08-13-2006 09:15 PM
Thanks for the advise, reading the tech note of each one the difference is that the A3 is cheaper than the #8 basicly! $2 difference.
alan0899 08-14-2006 02:11 AM
G'day Mate,
Remember you get what you pay for! The A3 is cheaper because it is a plated element plug, & will generally not last, because the plating comes off, or perform as well, as the OS 8.
bigtim 08-14-2006 04:15 AM
just ran my OS 46AX with the #3 stock plug and had a stutter when throttling up, changed to a #8 and runs smooth you get what you pay for applies I didn't think it mattered until I made the change .
Missileman 08-14-2006 03:44 PM
So far, and mind you I am fairly new at this, every #3 plug I have used has burned out after only a few flights, #8 I have had no problem at all with.
Skeeter- try a search here and see what you can find http://www.modelaircraft.org/clubsearch.aspx
cjposada 08-14-2006 05:22 PM
I fly out of Markham park in broward, there is other down in dade and like 4 private airfields that I know off.
I will take the advise and have a couple of #8 handy for when the A3 quits! Thanks for the answers.
Cyclic Hardover 08-14-2006 08:37 PM
ORIGINAL: cjposada
Well if you live in the Boca or West Palm area as my in laws do, ah your required to install plugs with at least a $25 value each:eek:
