RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Fuel Dot (https://www.rcuniverse.com/forum/beginners-85/4682099-fuel-dot.html)
mcoccia 08-28-2006 07:58 PM
Fuel Dot
Hi,
What do Fuel Dots look like? What are the best one's to use. I searched Tower and just don't see a picture of them.
Missileman 08-28-2006 08:04 PM
RE: Fuel Dot
1 Attachment(s)
here is an example
http://www.centralhobbies.com/Fuel/f...s/tetdots.html
Here is a pic of a bit fancier one
mcoccia 08-28-2006 08:10 PM
RE: Fuel Dot
Thank you:)
ORIGINAL: Missileman
here is an example
RCKen 08-28-2006 09:11 PM
RE: Fuel Dot
1 Attachment(s)
Hanger 9 makes a very nice fuel dot that doesn't cost too much. You can find them here [link]http://www.horizonhobby.com/Products/Default.aspx?ProdID=HAN115[/link]
Also, a few pictures for you
Ken
mcoccia 08-28-2006 09:18 PM
RE: Fuel Dot
Thanks again Ken:)
ORIGINAL: RCKen
Ken
Stickbuilder 08-28-2006 09:18 PM
RE: Fuel Dot
Fuel Dots are available from several sources. Tower Hobbies is not the end-all and be-all for this Hobby/sport. There is no way that one outlet can stock everything that you will need and want. Broaden your horizons and look elsewhere.
Bill, AMA 4720
raideron 08-29-2006 02:49 AM
RE: Fuel Dot
I like the Tettra Fuel double barbed dots from Central I'm sure you can get them else where.
I did not have great luck with the single barbed ones.... Tower's used to sell double barbed ones
and they may still do, but the last set I waited for was the single barbed ones...
shakes268 08-29-2006 09:37 AM
RE: Fuel Dot
I want to add that if you use a 2 line system with a fuel dot, make sure you put an inline filter between the T connector and the engine. The reason is you are pumping fuel in that could contain trash. This is especially important if you rely on a filtered clunk as you will have fuel in the line that never gets filtered by the clunk.
Fastsky 08-29-2006 10:47 AM
RE: Fuel Dot
The easiest way I found to have filtered fuel is to have the filter on the fuel line from the fuel pump. [8D]
Missileman 08-29-2006 01:47 PM
RE: Fuel Dot
ORIGINAL: Fastsky
Same here :D and one less obstruction getting fuel to the carb.
raideron 08-29-2006 03:26 PM
RE: Fuel Dot
I use both.... Can't hurt it, and I had no difference in RPM.... I use the duel screened
clear filter.... On my YS's I use the same setup and also have one on the press side,
thinking of doing it to all my planes... Cheap insurance IMO
