RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   wondering how to. (https://www.rcuniverse.com/forum/beginners-85/4838205-wondering-how.html)
jakcharles 10-07-2006 02:53 AM
wondering how to.
I wanted to know where I can buy a pilot that moves his head or how to go aout making one my self any idea's? Thanks in advance.
parrthd 10-07-2006 04:55 AM
RE: wondering how to.
how about using a "bobble" head........the kind like ppl put on the dashes of their cars....IF you can find one you like.
just a quick thought.
i've seen everything from G.I. Joe to barbie to spongbob squarepants installed as a pilot.
DavidAgar 10-07-2006 09:18 AM
The newer version of the Willaims Brothers plastic pilot's busts have the head seperate from the shoulders. I have seen where you would install a rod throught the sholders and into the bottom of the head and make it move by hooking it up to a seperate servo or the rudder servo. Works real well and looks good to. Good Luck, Dave
horace315 10-07-2006 06:39 PM
i think you could make one out of almost any pilot head/shoulders combo.use a paper clip drilled through the body and attached to the head,a little bit of soldering to that and connected to any servo.i have seen one with a hand that salutes before takeoff.just a thought...........
AIRPLANENUTS 10-07-2006 08:43 PM
Ditto what David said. I've done the same thing. I used a Williams Brother's pilot, a wooden dowel glued to the head thru a hole I drilled thru the bottom of the head and the center of the bust where the head rests. The dowel is inserted thru a hole drilled into the cockpit floor under the bust. Just beneath the floor, I glued a servo arm, of which the center hole is reamed out to the diameter of the dowel, to the dowel itself.
Once the pilot bust is glued to the cockpit floor, the dowel doesn't move laterally, only radially about its center. I attached the rudder servo arm to the bust's servo arm with a pushrod and clevises. Works like a charm!
Good luck with it.
