RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Beginner Radio Question: Dymond? (https://www.rcuniverse.com/forum/beginners-85/4863069-beginner-radio-question-dymond.html)
Cyler 10-13-2006 11:18 AM
*I am dual posting this in Beginners forum and Q's and A's forum to help get some responses.*
Has anyone ever heard of, know anything about, or used a cheap radio called "Dymond 4 FM Micro"? On the actual radio in the picture it says "Dynam". You can see it here: http://www.rc-dymond.com/index.php?productID=974
I've seen this radio tx advertisment in Fly R/C for a couple months now, and I was weary of it, but would like to think about it if it seems legit. I just dont like trusting people who don't even have a phone number on their website. Seemed fishy.
But with tx, rx, crystals, 2 micro servos and pc connection cord for $69 seemed like a good deal, but I want to see if anyone had anything to say about it.
Thanks for all the help!
piper_chuck 10-13-2006 11:25 AM
RE: Beginner Radio Question: Dymond?
I've never heard of them, but there is a phone number, in the upper right corner of the page you referenced.
Dr1Driver 10-13-2006 11:36 AM
You can get a Hitec just about as cheap. MUCH better radio.
Dr.1
bruce88123 10-13-2006 11:40 AM
No known facts but a wild guess (WAG) is that it is made in China or similar low-cost labor country. Quality unknown. Backyard flyer type radio only not for most nitro powered planes. Not much to lose if it turns out to be a lemon depending upon value of plane that may be lost.[:o]
RCKen 10-13-2006 01:11 PM
Ok, looking at your ad brings a few thoughts/concerns to mind
[ul][*] The ad doesn't indicate what frequency range it's in (72 Mhz, 75 Mhz, or 27 Mhz). 72 Mhz is for aircraft use, 75 Mhz is for ground use, and 27 Mhz is for both. If you get a radio that is in the 75 range you could end up getting shot down by somebody using a car in the area.[*] The ad states "Rechargeable battery and charger Combo only $ 25". This indicates to me that the radio runs on AA alkaline batteries. If this is true it can be dangerous for use in an aircraft. This because the spring loaded battery clips that are used can actually lose contact with the batteries due to the vibration of the engine causing the plane to fly out of control. Also, using alkaline batteries can get expensive very quickly. [*] Lack of bubby box facilities. It doesn't look like it has any way to connect a buddy box to this radio, which can make training to fly with this radio difficult.[*] The ad states "2 Micro servos 8 g light and small 4+6 Micro receiver". This indicates that it's intended for a park flyer setup. I don't know what your intended use is for this radio, but you plan to use it for a nitro powered plane you will at least have to replace the servos as the "micro" servos included with the radio won't be big enough to fly this with. In addition, the "micro" receiver may not have the range needed to fly a nitro powered plane and may need replaced as well.[*] Lack of support. Since it's not a "name brand" that most people use (i.e. Futaba, Hitec, Airtronics, or JR) you may find your options for repair are limited. It looks like it may be one of the new "China" brands that are showing up on the market.
[/ul]
As most have said above (and yourself included) I'd be a bit weary of this deal. Since you didn't indicate your intended use it makes it a bit more difficult to make a judgement, but if you plan on a park flyer this radio might be a "maybe". But if you are planning on flying glow powered aircraft I would stay away from it. If you look at Tower Hobbies you can get the bare bones Tower Hobbies brand radios for a pretty good price. While they say Tower Hobbies on them they are made by Futaba so you are getting a name brand radio.
Hope this helps
Ken
carrellh 10-13-2006 01:54 PM
I think Dymond has some good items, and their radio may be fine, but I'd spend the extra to go with a known brand.
If your planned model is a lightweght electric "park flyer" type, here is a link to a Futaba 4 channel system for 99.99
http://www2.towerhobbies.com/cgi-bin...I=LXGAE8**&P=0
One Futaba 4YF 4-channel FM radio system with charger, transmitter NiCd battery, frequency flags, neck strap, switch harness, two S3110 servos with four point horns, R114F receiver, and transmitter and receiver crystals
A Receiver NiCd or battery box is NOT included because radio system is designed for Park Flyers and thus power will be provided to the Rx via the BEC Electronic Speed Control (ESC)
KW_Counter 10-13-2006 02:36 PM
This dealer has been around for several years. I knew a couple of people who shopped there and I heard no bad comments.
There were three RC stores in that area - them, Hobby People and Hobby Warehouse. Don't know if Hobby Warehouse is still around.
I don't know a thing aboout the radio.
Good Luck,
KW_Counter
bruce88123 10-13-2006 02:50 PM
http://www.hobbywarehouse.com/
