RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Glow Igniter Dying (https://www.rcuniverse.com/forum/beginners-85/4909826-glow-igniter-dying.html)
LT-40 10-24-2006 05:19 PM
Glow Igniter Dying
I have a Hot Shot 2 that I have had for about 3-4 years, and recently it hasn't been able to hold a charge. Is there something I can do to make it last a bit longer? I also was wondering if I could cycle it. If so, how? I may just end up buying a new one, excepte this time I would like to buy one that just requires a AA so that I don't have to worry about charging.
LT-40
gunfighterII 10-24-2006 05:33 PM
RE: Glow Igniter Dying
Lt-40
Sounds like your ready for a new glow driver, try this one but get some rechargables as they eat batteries,
http://www2.towerhobbies.com/cgi-bin...?&I=LXJUJ6&P=0
KidVermin 10-24-2006 05:49 PM
As a backup, I solder together 4 D cell alkaline batteries to give 1.5v with longer duration. Electrical tape together and with an 18" cord to a press-on plug adapter.
LT-40 10-24-2006 10:13 PM
Thanks guys. The link to the glow driver that was suggested is the one I am considering. But the only problem is the part about you saying "they eat batteries" So how long can I expect a AA to last? Maybe I should just get another recargeable one. The reason why I wanted the AA style was so that I wouldn't have to buy a whole new driver next time. I may also try what HuskerBoy said because that sounds like the batteries would last longer.
Thanks, again
LT-40
KidVermin 10-25-2006 01:15 AM
LT,
I also have the HotShot 2 which has lasted almost 5 years now. You must have gotten a poor cell. I have the D cell pack just in case mine goes south while at the field.
rrragmanliam 10-25-2006 01:47 AM
ORIGINAL: HuskerBoy
I don't even use a glow driver anymore. Four D cells soldered together like Huskerboy said lights off everything I fly for an entire summer. Glue them together with silicone before you solder, they are much easier to handle that way.
Rrragman
-EXTRA- 10-25-2006 12:20 PM
Lt-40 get something like this its like what i have http://www2.towerhobbies.com/cgi-bin...?&I=LXD699&P=7 it comes with a rechargable battery and when it goes out you can simply replace it :) might find one cheaper at you LHS thats where i got mine
-EXTRA- 10-25-2006 12:22 PM
sorry i just say this one http://www2.towerhobbies.com/cgi-bin...?&I=LXJ801&P=7 thats the one i have but you have to buy a battery so still you can replace the battery when it goes out
KW_Counter 10-25-2006 01:58 PM
I would try cycling it. We have a habit of charging them frequently and never letting them get low.
To cycle I got a plug just like the one on the charger and hooked it to my cycler/charger.
Good Luck,
KW_Counter
