RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Lower to upper aileron pushrod placement (https://www.rcuniverse.com/forum/beginners-85/5124197-lower-upper-aileron-pushrod-placement.html)
coolbean 12-16-2006 07:17 PM
1 Attachment(s)
I have built from scratch a foam Untimate Bipe and I am having a hard time figuring out where to put the pushrods/horns to attach the lower and upper ailerons so that they move the same distance.
bigedmustafa 12-16-2006 08:46 PM
RE: Lower to upper aileron pushrod placement
Attaching the connecting rods in the center of the ailerons would give you the most consistent movement.
RCKen 12-16-2006 09:28 PM
What Ed said!!! :D
Ken
coolbean 12-16-2006 09:29 PM
I'm not concerned about where along the span to put them. What I mean is where in relation to their piviot points should I connect the rod.
RCKen 12-16-2006 09:34 PM
On the outside edge of the ailerons.
Ken
RCKen 12-16-2006 09:44 PM
1 Attachment(s)
Here's a pictures I pulled from the Great Planes Ulimate instruction manual. You can see how they do the pushrods here.
Hope this helps
Ken
