help with edge 540
i need help with a aeroworks 60/90 edge 540 i have just bought it and know i read the threads about it, how convienient, well i need to know how a moki 1.35 or a moki 1.80 will do on this plane and if the 1.80 will even mount on it.
Thank you malin |
help with edge 540
Both of those motors are too big for it.
I flew mine with a .91 2 cycle and it was good. Heavier motors will kill the intended performance of this plane. |
edge
so a saito 91 will pull out of a hover with no problems?
help with edge 540
Mine was a .91 two stroke. It would hover it fine but the pull outs werent rocket like.
I lived with that over putting a bigger motor in it and making the overall plane heavier. I dont know about using the .91 Saito. I dont think it would be any better than the 2 stroke I had in mine. |
edge
not to overmind you i am new and am verry interested in learning i looked at some specs for the moki's and the 1.35 weighs only 30.5 oz. but seems by the numbers that it would pull out alot better than my saito.
Do you have any ideas of motors that would give me a little more pull out than the 91's i just dont want to take any chances. malin |
help with edge 540
Malin,
Sure a 1.35 would pull it out if a hover much better than .91 would. But, You have to keep in mind that adding extra weight on a small plane increases the wing loading. Meaning the wing has to lift more. This plane was desinged to be a good 3D / aerobatic plane in a smaller package then whats generally available. Higher wing loading means the plane will stall faster, land faster and generally just not fly as good if it was lighter. If all your looking to do is hover, stick a huge motor in it and go have fun but I dont think you'd like how it flew doing anything else. When this plane first came out I heard people complaining that it flew like CR*P. Then I found out they were sticking huge motors in it and the weight on their planes was around 11 pounds. Way too much for a plane that size. Mine weighed less than 8 RTF. It really depends on what you want to do with it. I was OK with the slower pull outs because it did everything else well. |
thank you thank you thank you
i really apriciate it i only have one more question how did you get your weight down to 8lbs all other threads have read that it comes out of the box at 9.5-10 lbs. did you do anything or did these people put monster engines on them to get that weight.
malin and thank you again for the help |
help with edge 540
1 Attachment(s)
All I did was put it together.
Some guys were making the process of assembling that ARF way too complicated. Elevator bellcranks etc. I had my elev servos in the tail and the rudder on a pull pull. Easy. |
help with edge 540
thank you i really apriciate it i will use the saito that i orderd with it and save my moki for my next bigger airplane.
malin |
help with edge 540
You'll be happy with that i think.
Hey do you fly with Eddie Hill there in Wichita Falls? Tell him Wayne said hi if you do. |
help with edge 540
i sure do he is really good i get alot of advice from him. i will tell him hi for you.
malin |
help with edge 540
I am a corporate pilot and used to fly for Pennzoil when he was racing for them.
help with edge 540
thats cool. im in the airforce and am a mechanic on the f-16 i just got into the sport about 6mon. ago i have maxed out my trainer and have gotten prety good with a friends G200 the edge looked like a good aerobatic plane with some floating capibility.
do you have any sug. on a plane for a moki 1.80 that wont kill my wallet. |
help with edge 540
ARF or kit?
ARF.....Hangar 9 Edge or a Sig Extra 300XS Kit....... Midwest Cap 232 or Extra 300 |
help with edge 540
im one of those weekend flyers i need to fly now!!! if you know what i mean it will definatly be an ARF.
thanks for the sug. i will look them up. how big is your ultimate bipe? |
help with edge 540
the yellow and black one?
.46 sized. (Too small) |
help with edge 540
that was the one WAY too small but i bet some of the people that own these edge 540 wouldnt think so hahahaha
| All times are GMT -8. The time now is 03:39 AM. |
