RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Retract Servo Question (https://www.rcuniverse.com/forum/beginners-85/5198304-retract-servo-question.html)
fstevenj 01-02-2007 04:14 PM
I thought a retract servo rotated 180 degrees. Mine only seems to rotate about 160-170 degrees. Is that normal?
bruce88123 01-02-2007 04:21 PM
RE: Retract Servo Question
It could be normal depending on the model of the servo and settings within the TX.
What servo do you have?
fstevenj 01-02-2007 04:25 PM
Futaba, Can I change the endpoint settings for the servo? I have a Futaba 9C transmitter.
bruce88123 01-02-2007 04:53 PM
Any particular Futaba servo? A model number would be nice.
Check your manual for the 9C, you may be able to adjust it. I don't know if it matters but is the 9C a regular or a Super?
bruce88123 01-02-2007 05:12 PM
I found the following in the 9C Super manual
Retract servos are NOT proportional. Changing END POINT will NOT adjust the servo throw.
pg 32 of the manual.
MinnFlyer 01-03-2007 11:28 AM
1 Attachment(s)
You are actually much better off with 160 - 170 degrees of travel. Otherwise (With 180ยบ) you need to arrange your travel so the pushrods don't hit each other. To do that, they must go past the farthest point and return slightly so they don't hit each other when they are in the opposite postion.
Maybe servo manufacturers are finally starting to realize that.
fstevenj 01-03-2007 12:46 PM
I might be better off, but I had already set up the linkages for 180 degrees. Oh well just something else on this plane I have to redo. So it is not an issue that the retract only goes 160-170 even though in the Futaba literature it is a 180 degree retract servo?
MinnFlyer 01-03-2007 12:50 PM
Personally, I wouldn't worry, but then, I'm half crazy :D
If you're concerned, contact Futaba
RCKen 01-03-2007 02:19 PM
ORIGINAL: MinnFlyer
Only half?? :D:D
You're getting better then!! I guess the treatments are working!! ;)
Ken
bruce88123 01-03-2007 02:48 PM
ORIGINAL: RCKen
ORIGINAL: MinnFlyer
Only half?? :D:D
Ken
And since when are YOU in a place to make sanity judgements Ken? Hmmmmm?[sm=bananahead.gif]
RCKen 01-03-2007 03:10 PM
ORIGINAL: bruce88123
ORIGINAL: RCKen
ORIGINAL: MinnFlyer
Only half?? :D:D
Ken
;):D
Scar 01-03-2007 04:07 PM
ORIGINAL: fstevenj
You're going to redo, for six percent? That's sixty thousandths difference for a one inch travel. I wouldn't think you'd have to adjust the servo arm radius at all. None of my mechanical retracts would require that, and the air retract switch links I use wouldn't be that sensitive either.
Dave Olson
