RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Replacing starter cone (https://www.rcuniverse.com/forum/beginners-85/5663902-replacing-starter-cone.html)
Chondar 04-04-2007 10:18 AM
Hi all. I've been lurking here for a while and learning lots, so I hope you can help me.
My electric starter is a hand-me-down antique of indeterminate age but still works fine. Lately the rubber cone insert has started shredding a bit, so I found a new replacement that looks to be just the right size. Is there any trick to replacing these things?
I can see the starter has three tabs that fit into three grooves in the outside of the cone, and there's a nut flush with the bottom of the cup. Tugging (not too hard) on the old cone doesn't seem to move it. Is this a friction fit, is there glue involved, or what?
Jay
MikeL 04-04-2007 11:30 AM
RE: Replacing starter cone
On my Sullivan, which has lasted for many, many years, it's a friction fit. I regularly flip the cone around, depending on if what I'm starting has a spinner or not, or if I need the helicopter starting shaft.
bruce88123 04-04-2007 11:30 AM
No glue needed. What brand is it and model if you can?
bruce88123 04-04-2007 11:33 AM
A selection but not all that's available
http://www2.towerhobbies.com/cgi-bin...tarter+inserts
Chondar 04-04-2007 03:13 PM
I can find no brand or model markings on the starter itself. It has a black motor case with yellow handguard and trim. It is at least 10 and probably more like 20 years old.
The replacement cone is a blue Sullivan.
bruce88123 04-04-2007 03:22 PM
Does it look like this
http://www2.towerhobbies.com/cgi-bin...&I=LXFT84&P=SM
Chondar 04-05-2007 10:15 AM
Very similar. The handguard is a bit different, and there's no label.
carrellh 04-05-2007 01:21 PM
The insert is probably just stuck from being in the cup for many years. Before you order a new insert, measure the inside diameter of the cup. There are at least two sizes.
Chondar 04-05-2007 02:23 PM
Will do. Thanks, everyone!
-Jay
