MONOKOTE
How does monokote work??? Is it like shrink wrap? Does it actually stick to the balsa wood?? The reason I am asking is because a plane I have has real cheap and flimsy landing gear (hence i mean wire). So I have decided that in order for me to fly a local grass feild I would upgrade the landing gear to a thin aluminum stock. However I am a little confused as I was told by a local gentleman to just cut back the monokote and adhere the new landing gear to the balsa. I have not done this yet as I am unsure what will happen to the monokote if i were to cut it back. :D Alright so flood me with some info guys.
RE: MONOKOTE
Monokote is a heat-shrinkable "plastic" covering. The adhesive on the back is heat activated. Cut back the covering as advised and re-seal the fresh edges with a heat iron.
Dr.1 |
RE: MONOKOTE
Of course, it may not stick as well the second time.
Make sure the area is CLEAN before you peel the old covering off, Something else you should know: While "MonoKote" is a brand name, it is also a generic term like "Band-Aid" or "Q-Tip" There are different brands of covering, some will come off and go back on easier than others. Usually, heat will help you remove it. |
RE: MONOKOTE
I'm not sure why you'd want to remove covering and glue the landing gear to the balsa.
RE: MONOKOTE
Glue will give under the first half heavy landing.
Drill the aluminum and bolt it on, through the covering. |
RE: MONOKOTE
Somewhat off-topic, but wire gear in and of itself is not necessarily cheap and flimsy. Properly designed, spec'd and installed wire gear is a perfect combination of shock absorption and durability. I'm just throwing this out there as food for thought.
Erik |
RE: MONOKOTE
Erik is right. However - many "Pacific Ring" ARFs have landing gear made from cheap steel that is not heat treated AT ALL. This produces weak, easily bent langing gear legs of the type described.
Dr.1 |
RE: MONOKOTE
Well this decision was based on some other club members who have looked at the plane. It is a Great Planes Mini Supersportster. I was told with the flimsy landing gear id have somewhat of a tough time with the grass strip. I also asked the question because I would like to ad a wheel to the rudder also. I do also agree that a fastner of type would probably be better.
RE: MONOKOTE
RE: MONOKOTE
Yes. 400 size electric motor. 39.5" wingspan.
RE: MONOKOTE
Now, do you have ANY idea WHAT gear you are going to try to use? These small electrics don't like to carry a lot of extra weight.
BTW - I went to school in Kalamazoo. WMU |
RE: MONOKOTE
SWEET!!! Bronco's rock. Well I'm not sure what gear the stock size is but I have a Himax 2510 4100 coming so the brushless will be going on instead of the stock brushed motor. Last night at the field I was also given a suggestion to try the smaller wire landing gear. Take the wheel skirts off and put on I think they called the wheel locks (not sure it that is the correct term but i Know the lhs will know exactly what I need to do). Suggestion was made only because the wire landing gear has a piece of ply wood the holds it in the fuse. If the landing gear were to break I could screw this other gear right into the wood. The gear I have made up doesn't wiegh much more the wire if any. I haven't weighed it yet though. But being a machinist by trade I have lightened it up a lot and still kept the rigidity (I hope).
RE: MONOKOTE
You can lift any weight if you have enough power and speed but you have to land eventually and that will also need to be at a higher speed. I'm not all that up on electrics so I'm gonna let the others help from here. RCU also has a subsidiary called www.wattflyer.com dedicated to electric flight. Check them out. Also dedicated electric forums here on RCU.
RE: MONOKOTE
thanks I've been doing a lot of reading lately. guess my real question was answered awhile back. But I appreciate everything you guys have chimed in about.
| All times are GMT -8. The time now is 04:00 AM. |
