ac/dc converter
I have a battery charger that has clips for a 12V battery. I am looking for a way to plug it into the AC wall.
I would like a normal wall plug with positive and negative poles {kind of like a car battery} where i can clip the 12V clips onto. This way I could use it for both home and battery use. Any suggestions? |
RE: ac/dc converter
Use this link, [link]http://web2.murraystate.edu/andy.batts/ps/powersupply.htm[/link] , to find instructions for converting a PC power supply to provide you with 12v for your charger.
Hope this helps Ken |
RE: ac/dc converter
Yup, get a power supply.
They are around 60-100$ and well worth the money. Get at LEAST a 10 AMP PS. OR, if you know what you are doing, a computer power supply will work VERY well, you just need to solder some connectors or bananna jacks to the right leads and mount it in a box to keep everything straight and mobile. |
RE: ac/dc converter
[link=http://www.rcbatteryclinic.com/]R/C Battery Clinic[/link] has a page that describes using PC power supplies as a power source.
RE: ac/dc converter
any chance you can link me to a reasonable priced one?
RE: ac/dc converter
Here is a 350 watt PS for $8. This is about as big as they come.
http://www.surpluscomputers.com/stor...&item=ACC10330 |
RE: ac/dc converter
ORIGINAL: jigeye any chance you can link me to a reasonable priced one? Ken |
RE: ac/dc converter
Jigeye,
Go to Ebay and search for 12V power supply. I've got a 13 amp unit I paid less than $30 for. There are several on there. Some of the freights are high because they are coming from China. Also, one person convering and selling PC power supplies. Good Luck, KW_Counter |
| All times are GMT -8. The time now is 09:26 AM. |
