weird noise
i just fired up my alpha .60 a while ago for the first time and it was a little rough. the first time i started it it idled really rough and when ever i tries to rev it up it would start to die and it would make a clicking noise. it eventually started to run good but after i tried to start it again the same thing happened again. is this normal? and is a lot of oil in coming out of exaust normal? i know there should be some but at about half throttle it pretty much pours out.
RE: weird noise
without being there it sounds like it is running very rich. that is not a bad thing for a brand new motor on it's first run. the clicking I am assuming is after you run it and turning the prop by hand? If so that could be normal on a new engine as well. the best advice I can give you is to get with your instructor before you go any further.
RE: weird noise
What type of engine is it?
RE: weird noise
could that clicking sound possibly be the piston pinching the sleeve and pushing it up and down inside of the motor
RE: weird noise
Is the engine a four stroke? There was a thread similar to this a while back.
RE: weird noise
the engine is a evolution .61nt. and the clicking noise is only when i rev it up and then it starts to die. and when idle it sounds kinda sad. It may be running rich but it sometimes runs fine without any problems that i can see. the oil may be because it is running rich but i don't know much.
| All times are GMT -8. The time now is 04:34 PM. |
