RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   balancing (https://www.rcuniverse.com/forum/beginners-85/6165225-balancing.html)
rc-plane 07-27-2007 09:05 PM
balancing
Hey I have a yak and was wondering if you balance inverted or right side up thanks
Insanemoondoggie 07-27-2007 09:12 PM
RE: balancing
You can do it both ways, but you`ll find low wings balance easier inverted.
skeeter_ca 07-27-2007 09:15 PM
RE: balancing
Does balancing upside down place the CG in a different place then right side up or does is it just make it hang easier with the mass below.
Bad_Daddy 07-27-2007 09:22 PM
RE: balancing
No difference in the location, it just sits more steadily with the mass below the lift points.
Insanemoondoggie 07-27-2007 09:52 PM
RE: balancing
ORIGINAL: skeeter_ca
No , your CG stays the same , Like Bad_Daddy said, having the mass below the wing is just easier to balance them this way.
