RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   What will remove cured, thin CA glue? (https://www.rcuniverse.com/forum/beginners-85/620147-what-will-remove-cured-thin-ca-glue.html)
Paul Cataldo 03-13-2003 01:03 AM
Guys,
I spilled some thin CA glue on one of my expensive knife blades and I ended up scraping most of it off with an X-Acto blade.
However, there is still a residue mark where the glue dried, and I'm looking for suggestions as to what might rid my knife of this stain. ANY suggestions would be appreciated. Thanks.
paulfromero 03-13-2003 01:19 AM
Debonder
Hi,
You might try Great Planes brand "Pro CA Debonder" for this.
Paul
DMcQuinn 03-13-2003 01:24 AM
Acetone works also
You can generally get acetone at hardware stores, home depot, etc.
4*60 03-13-2003 02:12 AM
Yes, a quick soak in acetone should do it.
MinnFlyer 03-13-2003 04:00 PM
You may have etched the metal. If all else fails, try a metal polish.
Geistware 03-13-2003 08:46 PM
Use acetone. I have removed C/A hinges from control surfaces with the stuff!
strato911 03-13-2003 09:49 PM
I'm with MinnFlyer on this one. The Ph of the CA may have etched the surface of the blade. In the future, I assume you'll keep your expensive blades away from the plane huh? CA has a knack of getting on anything closeby - especially fingers. :D
rajul 03-14-2003 02:58 AM
No problemo ! Get a glass container or beaker that fit the blade sizes. Pour in some acetone. Soak them blades overnight. Cover the container to minimise evaporation loss. I use this method all the time to recycle my ca tips.
