RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   spektrum bind plug (https://www.rcuniverse.com/forum/beginners-85/6216321-spektrum-bind-plug.html)
goirish 08-09-2007 11:41 AM
spektrum bind plug
I have the spektrum 2.4 tx with the rx and bind plug. If I buy a new rx do I have to have a new bind plug or can I use the one I have.
CGRetired 08-09-2007 01:02 PM
RE: spektrum bind plug
All the bind plug does is put a ground (logical low) on the signal line. It is simply a jumper. So, you can use any one on any RX, and you can also make one of your own with a piece of thin gauge wire and some small female pins. Radio Shack has them.
DS.
mp_gohl 08-09-2007 01:41 PM
i agree with cg i have two planes on my DX7 i just used the bind jumper from the first one, all it does is create a temporary Short.
goirish 08-09-2007 02:33 PM
Great!! that saves a couple of bucks. :D
A6Ordie 08-10-2007 01:16 PM
Each receiver I've bought has come with a new one. You shouldn't run out them that way.
Good Luck,
