how to get decals off the sheet
I have a Goldberg Cub, how do I get the decals off the sheet?
RE: how to get decals off the sheet
What kind of decals are they??? I'm gonna venture a guess that they are stick on decals. Is it just one whole sheet of them? If so you'll need to use scissors or a hobby knife to cut out each individual decal. THen peel the decal away from the backing. Then apply it to the plane.
Ken |
boy, It don't look like you can peel them off. I thought maybe it was the kind that you soaked in water or some other solution.
Not familiar with Goldberg in particular but there are three common decal types.
Water-slide Die-cut self-adhesive Uncut self-adhesive Snip off a corner of the sheet and try to seperate the decal from the backing with the edge of an X-acto knife or razor. If that doesn't work soak the test piece in water and see if the backing absorbs the water and the decal covering slides off after 60 seconds or so. |
And on some die cut self adhesive decals, they don't cut 100% around the decal, so you need to be very careful when peeling. You may want to go around the outline with an exacto blade to make sure it will peel off cleanly without tearing the decal, especially with complicated shapes.
You COULD try asking the manufacturer which is NOW Great Planes.
Email: Please try to include as much information as possible when asking your question. Be sure to list your full email address (ex: [email protected]) as well as at least one other means of daytime contact in your email. Please note that we support a broad variety of types of products. For fastest possible response, please see the table below and send your email to the appropriate team. If unsure, simply send your email to [email protected] and we will forward it to the appropriate staff members. Please also note that listing the name of the specific product you are inquiring about in the subject of your email may help accelerate our response time. Aircraft and aircraft related products - [email protected] |
| All times are GMT -8. The time now is 11:34 AM. |
