Need rubber O ring
On my Cub, the TT.61RFS is leaking fuel from the high speed needle. The only thing I can think of is it's the rubber o ring. Any place I could get one other than ordering directly from the mfg?
thanks,, |
RE: Need rubber O ring
You might have luck at a local hardware or home depot. I'm not sure if their o rings will be fuel resistant, some might.
A little trick I've used before is to cut a small piece of fuel tubing and slide it over the needle valve so it covers the threaded section completly. Might work for awhile until you can get an o ring. ENJOY !!! RED |
If you know the size you want, then go to:
http://www.mcmaster.com and type in o-ring. You're sure to find it there. |
Ahh,,,geezzzzz, have no idea what I was thinking guys sorry. The engine is a Magnum 61RFS, not a Thunder Tiger,,,,sorry. :eek:
Any ideas,,, |
http://media.hobbypeople.net/manual/210985.pdf
Part number 12845 as shown in the part list. Where to find it I don't know. |
I`m pretty sure the size you need is a 3mm outside diameter with a 2mm inside. I have a Magnum .52 4c thats giving me the same problem . The HS and LS needle uses the same o-ring.
Bruce is right , that is the part # |
Cruz - I have a couple.
If you still are unable to find one - email me your address and I'll post you one. |
frugal,,,,sent you a PM. :D
I have cut o-rings down and used super glue to splice the ends . Never tried it on one so small , think I`ll give it a shot .
I'm thinking teflon tape might help as well?? Maybe?
I have used teflon tape on a couple of SuperTigres and it worked well, but I can move the HS from side to side , and not sure whats up. Going to tear it down and see whats going on.
Try going to a transmission repair shop that does foriegn cars. I have gotten some pretty small metric O rings from them in the past and they will usely just give you a couple when you show them what you are useing them for.
Cruz - I have mailed a replcement ring today.
Thanks a lot. I'll let you know when it arrives. :D:D:D
Received the rubber o-ring in perfect shape. Thanks a whole bunch.
:D:D:D |
1 Attachment(s)
Heres my fix, worked better than when it was new.
Is that just plain ol' fuel tubing on there?
ORIGINAL: cruzomatic Is that just plain ol' fuel tubing on there? |
Yep x-large. lol. Works great, takes a little fooling with.
| All times are GMT -8. The time now is 07:18 AM. |
