muffler question
Hello All, I'm assembling a Piper Cub ARF. The manual (which was translated from German) shows an OS 46 FX (which I happen to be using) with the standard muffler that comes with the OS.
Given that this engine has a cowl, can I/ should I use the "standard" muffler? Do people use a "Pitts" style muffler for the scale look, because of necessity (i.e. the cowl) or for both/neither? Thanks! |
muffler question
You can use the standard muffler or the pitts. With that standard muffler, you will have to cut out a bunch of the cowl to clear the muffler. The pitts will generally fit inside the cowl with just the two pipes sticking out of the cowl. This looks better, but is probably noisier than the standard muffler.
muffler question
Originally posted by DMcQuinn You can use the standard muffler or the pitts. With that standard muffler, you will have to cut out a bunch of the cowl to clear the muffler. The pitts will generally fit inside the cowl with just the two pipes sticking out of the cowl. This looks better, but is probably noisier than the standard muffler. |
muffler question
If I mount the engine sideways, does this mean I turn the engine bracket sideways in order to mount it correctly?
muffler question
yes, the engine mount is rotated 90 degrees so that the two beams that support the engine are vertical instead of horizontal.
muffler question
Originally posted by DMcQuinn yes, the engine mount is rotated 90 degrees so that the two beams that support the engine are vertical instead of horizontal. |
| All times are GMT -8. The time now is 03:00 PM. |
