case
Hello again question number two. OK, I was looking and saw that the case for the spectrum DX7 is $60. Can I go to home depot to make my own case or do I need to save up and buy there case? Have any of you guys made a case or just buy theirs.
RE: case
You can get a really nice case from the Home Depot. If it does not come with the foam in it head over to the craft shop and get a piece of foam big enough for the case. Then gently cut out the slot for the transmitter to fit into. Good Luck, Dave
RE: case
Any sporting goods store that sells gun cases will have nice, sturdy protective cases that will work well with your Spektrum transmitter. They come with the foam you need and you simply cut out the foam to fit your transmitter as needed.
Tower Hobbies sells gun cases as transmitter cases, but sporting goods stores should have them for slightly less. |
RE: case
I got my case a lowes. It's all alluminum and even came with the foam and holds two transmitters.
Austin |
RE: case
You can get cheap gun cases from Tower
http://www3.towerhobbies.com/cgi-bin...case&search=Go I can put two transmitters in the $16.99 case |
RE: case
Thanks that gives me a-lot of options. At least I know im not crazy:D
RE: case
If your budget is spartan, Tower has a Dubro one for $5.99
http://www3.towerhobbies.com/cgi-bin...?&I=LXAZG7&P=7 |
RE: case
Seemefly..are you talking about a carry case or a transmitter tray you would use at the field?
CGr |
RE: case
cg a carry case and for protection
RE: case
I bought a used case that someone had stripped out the foam from, and I cannot find the foam ANYWHERE!! So I'd reccomend buying a one with the foam in it already. I looked in all major craft stores, wallmart, lowes, home depot, fabric stores, etc.. IMPOSSIBLE to find. Sucks.
RE: case
Ah.. Ok. You have plenty of recommendations.. so go for it!!! ;)
CGr |
RE: case
look on here in the classifieds i found one new for 30 bucks with extra foam
RE: case
look at habor feight they have one for 20 and one for 30 the 30.00 one is pretty nice but the cheap one isnt to bad
RE: case
Grlllsfly.. If you go to Lowes or home depot and to the heating and cooling section. Most stores have the fairly dense black insulating foam. It works well and cuts nicely if care is used.
Also most stores that carry fabric for sewing will carry foam for projects like cushions etc. I use an old, old Bell telephone tool kit. Its metal and covered in leather and has a panel in the lid that flips down to hold small scale tools. I purchased foam, cut to fit and it works well. |
RE: case
1 Attachment(s)
Found a large camera case at the local discount store( job-lot). Holds tx plus room for smaller items. $2.99. Works great.
venom |
| All times are GMT -8. The time now is 03:38 AM. |
