RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Engine Help (https://www.rcuniverse.com/forum/beginners-85/6968561-engine-help.html)
F-15 Fan 01-25-2008 03:10 PM
Engine Help
K & B .61 2 Stroke
Which direction do I move the needle valve to richen or lean?
Also, my bearings were gummed up, I cleaned them, but now it seems like there is a little almost non-exsistent con rod slack, is this serious?
Please help me, thanks.[8D]
MinnFlyer 01-25-2008 03:38 PM
RE: Engine Help
Just as you turn a screw clockwise to tighten it, screwing the needle clockwise will screw it deeper into the hole - which lets less fuel in, thereby making the mixture leaner.
Not sure on Part 2... Did you remove the con rod during the cleaning?
F-15 Fan 01-25-2008 03:44 PM
RE: Engine Help
No, I am running it a bit right now, and it seems like it recorrects itself, and starts to run smoother.
Thanks on the needle valve though.
F-15 Fan 01-25-2008 05:06 PM
RE: Engine Help
Now it has ALOT of compression.
