GB Cub Engine
1 Attachment(s)
Hey all how you been doing,
I spotted this engine and wanted one last session of opinions before order, i know i should have gone with a four stroke but this is one of many planes i will built, O.S. 55AX ABL w/Muffler PLease post any comments and info Thanks Seb |
RE: GB Cub Engine
1 Attachment(s)
This also Came up !:)
Magnum XL-70RFS 4-Stroke Either way one or the other will be companied by a Pitts style Muffler Looks much more like a real plane Or Magnum XLS 52A Or Magnum XL-70RFS NIB |
RE: GB Cub Engine
You don't need a pitts style muffler with a 4 stroke.
RE: GB Cub Engine
im putting that magnum in mine, I cant imagine a cub with a 2 stroke.
RE: GB Cub Engine
Yeh im on the verge of buying that magnum myself
And what do u mean it dont need the pitts style muffler ? |
RE: GB Cub Engine
The muffler on a 4 stroke is quite alot smaller than a two stroke and can be angled to where you want it.
The muffler on a 4 stroke will fit inside most cowls or very little will stick out. |
RE: GB Cub Engine
Would u recommend that Engine then
What else should i be prepared to buy for it ? Thanks tonz Ps. i see this one being in competition with the Os 70 surpass ? |
RE: GB Cub Engine
I have nothing but good things to say about the Magnum 4 stroke engines.
For a Cub? Absolutely |
RE: GB Cub Engine
I have an OS 55AX and it is a FABULOUS engine...
But the GB Cub just BEGS for a 70 4-stroke! And like Missleman said, you can use the stock muffler. Sure it might stick out, but not as bad as a 2-stroke muffler - and once it's airborne, you'll never see it |
RE: GB Cub Engine
1 Attachment(s)
This is a H9 Cub with a OS FL .70, You can see the exhaust sticking out the bottom. The .70 works well.
RE: GB Cub Engine
Right on those are the comments i wanted to hear i think itll be a good flying plane being the clipped wing
RE: GB Cub Engine
I have a Magnum .70RFS in mine. Get it,,,,you'll be happy. :D
RE: GB Cub Engine
Done deal, its on its way :D:D:D
I went with the MAGNUM XL-70RFS I would like to thank all of you'se for taking the time to help me out with this |
RE: GB Cub Engine
Atta boy,,,,you did good. ;)
| All times are GMT -8. The time now is 07:07 PM. |
