RE: Nexstar Engine Mount
You don't HAVE to unless you want an answer to your question or a replacement plane.
I know, just frustrated (and broke!) and venting.
The first guy I talked to at Hobbico wasn't all that friendly, and tried to blame the problem on the changes from the FXi to the AX, and was trying to convince me to dremel out the portion of the plane contacting the muffler, even though it would essentially end up going through the plane behind the firewall, and didn't want to hear about any of the other problems, including all kinds of missing hardware. Then the way he said to disassemble the plane and repack it sounded like such a chore. I called back to talk to someone different. They were surprised at how many issues I've had, and said that it was extremely uncommon. They said to take out of the plane whatever I wanted to keep, and just get it in a box and send it in, not worrying about how its packed or disassembled. In a kind manner told me they would take care of the problem and send me a replacement, and told me of what some of the common problems are (none of which I experienced.) It's amazing what the difference between 2 customer service reps can make. I was psyched to get the prop spinning this weekend, but it will happen eventually. |
Hi,again,
Spent the better part of last flying season tweaking my Nextar. After performing a spectacular "ground loop",I had to replace everything from the windshield forward.Replaced everything from windshield forward, moved engine mount[original] 3/32" to left,built in1/2 degree right thrust, 2 degrees down thrust,added two nylon guides to nose gear and replaced n. gear with one having a longer shaft. Also changed incidence on hor. stab to 0 degrees [original from factory was 4 3/4 degrees neg. Handles a WHOLE lot better on the ground and no longer requires left rudder input on take off. Good luck, Fredsedno |
| All times are GMT -8. The time now is 05:16 AM. |
