RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Prop installation question (https://www.rcuniverse.com/forum/beginners-85/738203-prop-installation-question.html)
kerrydel 05-02-2003 01:30 AM
I have an OS .46 LA engine and a Master Airscrew 11x6 prop. My question is, how do I assemble the prop on the engine shaft? The hole diameter in the prop is smaller than the engine shaft. Should I ream the shaft? :confused:
Kerry
kerrydel 05-02-2003 01:31 AM
DOH!
That should have been "ream the HOLE" :stupid:
Woodsy 05-02-2003 02:15 AM
is it realy to small or just tight? if its WAY to small just ream it out if it's just tight spin the prop on.
rajul 05-02-2003 02:44 AM
Hi woodsy, get a prop reamer from GP or other brand. It's real easy and precise to use. The reamer has several steps for different shaft sizes. Good luck.......
RedWing 05-02-2003 10:56 AM
1 Attachment(s)
I have used Master Airscrew Props in 10 and 11 inch sizes and never had to ream them out. I have had them on OS, TT and Tower engines. I think the prop is just tight. Like Woodsy said first try to spin the prop on.You are talking about the black Master Airscrew props?
kerrydel 05-05-2003 07:45 PM
Well, I put the prop on this weekend. It kind of threaded itself on. Hope this isn't going to weaken it. It's survived one tank of fuel so far.
Thanks for the help
Kerry
