Servo choice for 60 size plane
Hi,
I'm getting ready to order a 60 size warbird (BH Models T028 Trojan), and trying to decide what kind of servos I need. Can I get by with some fairly low end servos (like S3001 or HS-425BB) with 42oz/in holding power? Or do I need to step up to higher end servos? Can I get cheap servos let's say for throttle and flaps and better ones for ailerons, elevators and rudder? Thank you for your feedback and recommendations. Remy |
RE: Servo choice for 60 size plane
I use futaba stuff mainly but the 3004 or equivalent will do just fine http://www3.towerhobbies.com/cgi-bin...&I=LXVW07&P=SM
Any servo should work fine, but are you sure you want a warbird? many other planes are more enjoyable to fly.
The S3001 or HS-425BB either one will be fine. I like the 425 better myself.
Many thanks for all the replies.
Do you think I'd get bored with a warbird? I currenlty fly a Mini Ultra Stick. It's a fun electric 40" wingspan sport plane. I am interested in getting a larger ship, 60 size glow. I like to the warbirds for the scale look and flaps. The other option I'd consider is somethink like the Great Plane Revolver or similar. Thank you for your feedback. Remy |
Hello Remy:
There is plane which is supposed to fly very well and it has flaps, the Phoenix Tiger 60. Also, it's quite cheap. I hope that helps. Bye, Ian |
What ever servo you get, make sure it's a ball bearing servo. Over time bushing servo's can wear which can lead to slop and possibly flutter. The Futaba S3004 servo will work fine for your application.
Hogflyer |
| All times are GMT -8. The time now is 11:11 PM. |
