RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Fixing Avistar Horizontal Stab (https://www.rcuniverse.com/forum/beginners-85/7527666-fixing-avistar-horizontal-stab.html)
n19htmare 05-28-2008 11:45 AM
RE: Fixing Avistar Horizontal Stab
If looks aren't a factor (meaning you dont care if it's all white), you can buy some monokote trim sheet for about $5. These have an adhesive back so they just stick on. How well? that I don't know. But from the damage you might be able to get away with it. This is a poor man's fix. The covering probably won't be tight which could effect the flying.
$20iron, $11 roll of monokote. Iron will last your forever (hopefully) and a roll will last you a few fixes.
bruce88123 05-28-2008 12:25 PM
I tried a trim sheet once before - CRAP IMO. But maybe I got a bad piece.
ScienceisCool 05-28-2008 12:55 PM
Alright, I'm going to use Monokote then to re-cover the area. Any suggestions about which brand of iron to buy? Are the more expensive (~$20) ones really better?
Nathan King 05-28-2008 01:06 PM
The Coverite iron is probably the best out there. The Hobbico iron is good too.
n19htmare 05-28-2008 02:08 PM
I got a hanger 9 for $20 and it's adjustable temp. I didn't get a sock, i just used an old under shirt :). Now you'll have an iron to use it on whatever you please :). Maybe when you make your own kit :)
Adui 05-28-2008 02:56 PM
ORIGINAL: ScienceisCool
I don't think I have the right tools to make a scarf joint so I'm going to try bending it back into place and using thin CA to hold it. I just have to run by the hobby shop and get some straight peices for bracing and some clamps. Then have to convince the wife to let me buy some monokote and an iron. Is there any other way to recover it without resorting to that?
Trust me, you will regret NOT doing it right the first time, I just had to redo the covering on an aileron repair I just slapped together and BOY was it a mess to fix it right after glue and taping it..
Follow the advice given, sweet talk the wife type, and get the iron.
bruce88123 05-28-2008 03:03 PM
Tell her she can borrow the iron for your shirt collars.:D
ScienceisCool 05-28-2008 04:16 PM
LOL! It's pretty hard to fly your models when your wife cuts off your fingers. :)
I do plan to start building my first kit but that won't be for a while, maybe late summer or early fall. Have a baby due at the end of the year. I'm sure I can convince the wifey to give me $30 for the repair job. And then some more to upgrade the wire landing gear. ;)
ScienceisCool 09-02-2008 04:16 PM
Finally ordered the Monokote, iron, new landing gear, glue etc to get this thing fixed. I got some clamps at Home Depot and some small pieces of plywood to straighten out the stab. Once I get the stuff in next week I'll post pics of the repair job.
bruce88123 09-02-2008 06:22 PM
WOW - nothing like dragging out a project. Hmmmmm - done that before too.:D
ScienceisCool 09-03-2008 11:33 AM
Haha... I blame my wife. :)
ScienceisCool 09-17-2008 10:29 AM
I've gotten the stab straightened out and glued with thin CA. Now I just need to cover the hole. Do I just cover the area i've already stripped or remove all the covering from the side and recover all of it? Does Monokote stick to itself well enough to hold together during flight? Also, do I cover it in one strip running from the top around to the bottom or two separate pieces, one for top and one for bottom? This is my first time using covering so it will be an adventure.
Thanks!
ScienceisCool 02-18-2009 02:49 PM
1 Attachment(s)
Ok, it's been a while but I finally got pics of the repair and landing gear upgrades. I removed the monokote from the area that was broken and re-covered it with plain white monokote after cleaning the area with windex. Some of the edges didn't seal well so I put scotch tape to close it up. I mounted the dubro landing gear back a little ways on the fuse so the bolts that hold it on go up through the servo tray.
I'm wondering, are the mains too far back? Hopefully it won't mess with the CG too much or cause any problems.
Comments?
Thanks!
w8ye 02-18-2009 03:07 PM
It will effect the take off a little but you will get used to it
rlipsett 02-18-2009 03:23 PM
monokote sticks to itself great but your problem is that fuel residue prevents the glue from sticking well. you have to really clean the monocote but if still lifts i use a dab of thin ca to hold the edge or clear nail polish to seal the edge
ScienceisCool 02-18-2009 03:41 PM
I tried to get rid of the fuel with the windex and it did get most of it off. The parts that I was having trouble sticking were where the old covering was wrinkled and I couldn't push down on the new stuff to touch the old to get it to stick without doing damage. I tried ironing the old stuff to stiffen it up but that didn't work so I sealed the edges with scotch tape which seems to be ok. I'm going to keep an eye on it after the first flights and if it decides to come loose I'll try the CA fix.
Thanks!
Anyone going to Scobee field this weekend and want to help me re-tune my engine? :)
bruce88123 02-18-2009 03:42 PM
It will require more elevator to rotate for takeoff IF the CG is correct. If the CG is wrong all bets are off. Check and correct the CG if needed. Aft gear movement and tail repair will most likely cause a CG shift to the rear - not good if too much.
w8ye 02-18-2009 03:46 PM
Did you re-check the balance on the plane?
ScienceisCool 02-18-2009 03:51 PM
I haven't re-checked the CG yet. I'll check it when I get home tonight and try to measure how far back from the LE it is. Anyone know where it's supposed to be on the Avistar? I can't remember.
How off would be too off and what would I do to fix it? I'm guessing adding weight to the front but how?
w8ye 02-18-2009 03:52 PM
Balance it on the main spar
hugger-4641 02-18-2009 10:00 PM
3 1/4" back from the LE is where the Cg is supposed to be, if its 3 1/2 it will be fine and will lift off a little quicker, but I wouldn't go much more than 3 1/2"
w8ye 02-18-2009 10:15 PM
Quote from the manual. . . . .
Use a felt tip pen or a narrow strip of tape to
accurately mark the balance point on the bottom of
the wing near both sides of the fuselage. The
balance point (CG) on the Avistar 40 is located
3-1/4" (83mm) back from the leading edge.
The point at which your model should balance for
your first flights. Later, you may experiment by
shifting the balance up to 5/16" (8mm) forward or
back to change the flying characteristics.
Moving the balance forward may improve the smoothness
and arrow-like tracking, but it may require more
speed for takeoff and make it more difficult to slow
down for landing.
Moving the balance aft makes the plane more agile
with a lighter and snappier feel.
Please start at the location we recommend and do
not at any time balance your model outside the
recommended range
delman 02-18-2009 11:05 PM
You might try cleaning with alcohol after the initial windex wipe down if you want the patch covering to stick better. It has worked better for my repair patch jobs. For balance adjustment move the battery forward - it might fit under the fuel tank if needed without using additional weight. I have done that on a couple of planes.
hugger-4641 02-18-2009 11:32 PM
I guess my memory aint too bad yet huh w8ye. Actually, I've put three of these together in the last year and all of them required me to put the battery aft of the servo's to get the Cg in the right place. One of them even required adding some weight to the tail, but this was probably because I moved the .46 magnum a little foward and used a lot of epoxy when I took the dihedral out of the wing.
w8ye 02-19-2009 01:19 AM
You did good Hugger.
I enjoy that you enjoy the Avistar. It is a good plane
