Correct engine temperature
What temperature reading should I get from the head of a O.S 46AX? 280F?
RE: Correct engine temperature
I used to keep mine to about 230*F - 240*F ... heat is not good for the engine. :)
240 is might cold for these engines.
I've seen reviews in magazines, which run the engine to 350 or more and suggest a head temp at the plug of around 310. |
| All times are GMT -8. The time now is 05:55 PM. |
