first kit build
hello,
I will be starting my first kit build soon. It's a Sig Ryan STA 60, not really a first kit, but was given to me. Anyway, I was hoping someone could make a list of things I will need to make it, all I already have is CA, sandpaper, wood glue, hobby knives, and a dremel tool. Also any miscellaneous build tips would be appreciated. thanks |
RE: first kit build
A flat building surface
T pins Epoxy Wieght Wax paper Triangle Ruler Sanding bar. Take an inventory of the kit before you build. Read the instructions a couple times. Study the plans a little bit....left wing, right wing or inverted fuselage..etc Build one section at a time. Measure twice cut once Mark the parts |
RE: first kit build
I have been using a "Mouse" electric finish sander to speed up in making parts fit, verses using an ordinary hand sander. With 220 grit on it, I can also sand joined sheeting quickly, without removing too much wood, making sheeting weak.
You might want some of the spring clamps that you get at Harbor Freight, about $3 for a tube with about 20 of them in there, of different sizes. Very handy to hold parts while the slower curing glue sets up. With the warm weather, watch out for the 30 min. epoxy, it will tend to set rapidly. If you do a wing, where the fit is more critical, get a small batch of 1 hr epoxy, just to give a little more work time. Good luck! |
RE: first kit build
30-minute Epoxy and a Razor Saw
RE: first kit build
don't build two left wing halfs, or vs versa........:D
RE: first kit build
when I'm bonding wood to wood in the main structure, what glue do I use? Seems CA would be too brittle, or is it OK?
RE: first kit build
CA is great if the joint is relatively close fitting. I do the bulk of my building with CA, using epoxy only for heavily loaded connections (wing joiners, firewalls, tail feather attachment). If you're using CA, use medium and thin for the bulk of the work. Thin is useful cause it hardens the wood and will wick into it, but this can add weight if one uses it excessively. Medium is best for the bulk of the build. thick is useful occasionally, but not really. Speed the build even further by using CA accelerator to cause it to cure NOW.
CA allows quick, pinless building. Many people, however, are irritated by the fumes and dislike the hard fingertips after a night's work. You can also use carpenter's glue for the bulk of the assembly, tho this requires pinning and clamping and slows the build. Reserve the epoxy for only the few high-stress joints, as it's quite heavy. Even with CA and wood glue, it's quite possible to add ALOT of weight to a plane. Whatever glue you use, ensure you've got some decent ventilation. Even balsa dust is irritating after a night's sanding. Building's fun! Have a blast! J |
RE: first kit build
thanks
RE: first kit build
also, what do I build on to stick the pins in? I used to build rubber band planes on top of cardboard, will it work in this case?
RE: first kit build
1 Attachment(s)
I use 2' by 4' accoustic ceiling tile, works pretty well. But where did you find the Sig Ryan STA? I'd sure like to try one. I've been "assembling" a Nitro Planes Ryan PT 20 and it's pretty much junk. Really difficult to make it fit and the end result is not very satisfying.
| All times are GMT -8. The time now is 07:29 PM. |
