RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Rtf airplane battery problem (https://www.rcuniverse.com/forum/beginners-85/7603590-rtf-airplane-battery-problem.html)
JackBiplane1 06-10-2008 02:16 PM
Hi, i have a Biplane with a 600 mah battery that i find very underpowered. Would i be able to replace it with a 1000 mah battery from a Hobbyzone Super Cub without any consequences i.e having to reprogram the radio, or burning out the motor etc... ? Thanks
Blazer1 06-10-2008 02:43 PM
RE: Rtf airplane battery problem
You need to make sure the VOLTAGE is the same, that is what you are concerned with, not the capacity. Mah is how much capacity the battery has and voltage is the power. If the voltage on the packs are the same and the pack is not to heavy you will be fine.
bingo field 06-10-2008 03:16 PM
Also, recheck your Center of Gravity, the extra weight will affect it.
RedGN 06-10-2008 04:13 PM
If it's very unpowered a larger battery won't do too much. You should also look into changing the motor maybe. Along with the larger battery , new prop, and probably a new esc may be needed. This might run you a couple of $$$ so ask yourself it's worth it for that plane.
Hope this helps
