asp 46
:eek:I have an asp 46 early to mid 90's that needs o-rings for carb where can I find a spec page ?
RE: asp 46
Engine should be virtually identical to a Magnum .46 of the same time period. You should be able to find suitable replacement parts at http://www.hobbypeople.net Just look for XL series replacement parts rather than XLS series and you should be set.
After a little digging, this should be a match: http://www.hobbypeople.net/guru/hps_317553225.asp |
| All times are GMT -8. The time now is 03:06 AM. |
