Thunder Tiger 61
I have a thunder tiger 61 that runs great. The problem is; when the barrel is completely closed the engine just continues to idle at a very slow speed. It just doesn't want to quit. Any suggestions? I don't want to fool with it too much because it runs so good. I have to stop it by removing the fuel line or pinching it off. I have throttle stop but that won't do it.
RE: Thunder Tiger 61
Morning, Irish. You can always throw a rag into the prop.. [X(] oops.. sorry about that.. :D
Had bacon and eggs with homefries this morning. Toasted English.. decaf Dunkie Do coffee. Got some left over if you're game! Dick. |
Sounds like your carb is sucking air at the attachment point Gene.
Try loosening the carb, then press it down against the O-Ring as you re-tighten it. If it IS leaking air at that junction, this should correct it - of course now that it is no longer sucking extra air, you will probably need to adjust the needle valve to compensate. |
Yep, air leak. Could be at the rear cover too. All it needs is ANY path into the crankcase. Had one like that once on another guys plane. Mystified us all until we found one carb mtg screw was missing - air path.
I had this exact problem with my TH .61. I tried loosening the carb and pushing down on the o-ring but still could not get it to shut down. Finally, I used a toothpick to spread a light coat of silicone on the carb barrell between the the o-ring and the engine case. I reseated the carb and tightened it while holding it down. I let the silicone cure overnight. That solved the problem. It runs great now, but as Minnflyer says, you will definitely need to adjust the mixture......high end anyway.
Gee CG a little late for Breakfastwhat's for lunch. Took my grandson to the field this morning. Little snot is learning faster than I did.
ORIGINAL: goirish Gee CG a little late for Breakfastwhat's for lunch. Took my grandson to the field this morning. Little snot is learning faster than I did. |
Hey Bruce-you are my kinda cook. Nothing like healthy leftovers.
Moldy spam on moldy bread is more like what us old Coastie's are used to.. :D
Yeah, Gene.. those darned kids are something else, arn't they. Jeech... puts us old farts to shame! |
Only his 3rd time out. Doing loops, rolls, split S's and cuban 8's. Only had to take it back twicehe let it get over head and he couldn't tell what it was doing. If he only knew (granpa couldn't either).
ORIGINAL: goirish Only his 3rd time out. Doing loops, rolls, split S's and cuban 8's. Only had to take it back twicehe let it get over head and he couldn't tell what it was doing. If he only knew (granpa couldn't either). We have a kid in our club, he usually comes out with his grandpa. He flys about 10 feet over the ground. The only time I'm 10 feet over the ground is when I take off or when I am landing, and that's briefly. This kid does it all at that height. Jeech.. |
ORIGINAL: CGRetired ORIGINAL: goirish Only his 3rd time out. Doing loops, rolls, split S's and cuban 8's. Only had to take it back twicehe let it get over head and he couldn't tell what it was doing. If he only knew (granpa couldn't either). We have a kid in our club, he usually comes out with his grandpa. He flys about 10 feet over the ground. The only time I'm 10 feet over the ground is when I take off or when I am landing, and that's briefly. This kid does it all at that height. Jeech.. |
Hey CG
Breakfast is on!!! French toast on oatmeal bread, warm syrup, 2 strips bacon not crisp and yes I did get you some Starbuck coffee. Come on down. |
Sounds good, can I come too ;)
RCU breakfast meeting at my place. Ya all come.
Oh, man.. I just signed on. Been busy this morning, and it's noon. Ah, Irish.. those french toast still warm?
Dick. |
Gee I must confess, I ate em. They just kept saying "pick me, pick me"
| All times are GMT -8. The time now is 10:46 AM. |
