RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Need RC Clamp and music wire (https://www.rcuniverse.com/forum/beginners-85/7909736-need-rc-clamp-music-wire.html)
747 09-01-2008 08:21 PM
I am gluing the fuse of my plane. The balsa is cracked in a joint. I need to hold em tight.
What do you guys use to hold things for a while Is there a Clamp for RC?
Where do I buy RC store or Home depot?
AND
Also need 0.039" music wire , where do I buy it?
Pls suggest
TIA747
smokeyser 09-01-2008 08:34 PM
RE: Need RC Clamp and music wire
Home depot will probably have C-clamps cheaper than the hobby shop. If it's a really odd shaped part that can be held together from the outside, have you considered rubber bands? They work great on curved stuff that's difficult to clamp properly.
TedMo 09-01-2008 08:36 PM
Really hard to understand what you're saying and what you need for clamps?If you use CA glue clamps are never needed. Sometimes depending on need I have used rubber bands for clamping. Also just straight pins will help. It all depends on what the task is to decide if and how it may be clamped
ChuckW 09-01-2008 09:49 PM
Harbor Freight is a good place for cheap clamps in assorted sizes. Just about any hardware store will have them too.
mikenlapaz 09-02-2008 03:15 AM
http://www3.towerhobbies.com/cgi-bin...&I=LXVET2&P=ML This package has some 1mm which I believe is what your looking for.
