Battery Problems For Super Cub
Hi all. I have run my supercub well once. But i have always had problens with the battery loosing its connection. And i have tried 2 connect it every way possible. I have watched the dvd and done that. But i get no response. What could the problem be, is it just me or maybe a faulty part? need help please.
RE: Battery Problems For Super Cub
The connector may be at fault. I had a ready to fly plane that I lost the battery in flight. Luckily the engine quit the plane went over in the neighbor's yard.
One of the little metal connectors inside the plastic body of the plug pushed backwards and wasn't actually connected. http://image2-6.rcuniverse.com/e1/ga...4/lg-12719.jpg |
ok then i will have a look ty
it still doesnt work
the part may be faulty in the connector or the battery may not be charged?
Is there anyone around you that could help you or a hobby shop you could take it to? At this point I would be wanting to measure voltages etc but I figure you are not able to do that? |
yes i am going into my hobbyshop 2moz for second look but i think it may well be the connectors on the end of the batterys
oh and yes i can check the voltage, i just need to borrow my dads friends volt meter (ammeter) ok thanks |
I would do all that
hi um i just put my batterys in my charger and they are responding to my charger but not my plane? im confused, what do u recon is wrong with it then
do u stil think the connectors? coz i dnt no what to think hehehe |
One thing on the battery powered planes is that the transmitter throttle must be completely off when you plug the airplane battery in or they will not work until you bring the transmitter throttle lever back down to off.
i tryed that but it makes no difference, ill c what my hobbyshop say bout it, hopefully they will no what to do
i think it is the connection |
At this point I think that is what you should do
what take it in to a hobbyshop?
coz they are closed today which is anoying i will hopefully go tomorrow ill keep trying to get it work untill tomorrow ok thanks alot |
ORIGINAL: Super-Cub-boi But i have always had problens with the battery loosing its connection. |
yes i realised that it might be the reciever now but i just wnt to get it up and flying, so it hink it is the reciever so how do i fix it? is it easy to fix?
ok thanks happy new year |
I bought one but gave it to a friend, and didnt even really look at it, does it have an actually receiver or is it one piece that has servos attached to it?...Your not leaving the battery plugged in are you?..he did that,not knowing any better and killed one of the batteries...is it just the motor or does anything on the plane work?..lastly are there batts in the transmitter?...does the motor/prop turn ok by hand?...Rog
1 Attachment(s)
i will post a picture in one second
it will just stop responding sometimes in mid air so i dont want to fly it until it is fixed, if you no any links to parts which i can buy in uk £ i would be much greatful have these picturs been sent? lol i dont no |
no i dont leave it in, i turn the radio on attach the battery then it wont respond ,then when i have finushed take out the battery and turn of the radio
no everything wont respond at all, but i touched the rods buy accident then it made a little sound, so i think it notices the battery but nothing else would work and when i take the battery out and touched the rods there were no sounds, so i think it reads it but nothing would work yes the prob turns fine buy hand thanks - Super-Cub-boi |
| All times are GMT -8. The time now is 11:50 AM. |
