RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Glow Plug Question (https://www.rcuniverse.com/forum/beginners-85/832340-glow-plug-question.html)
Joe Ortiz 06-04-2003 01:21 PM
Glow Plug Question
What's the difference between the plug that has an idle bar versus non idle bar :confused:
Jim Schwagle 06-04-2003 02:12 PM
Glow Plug Question
All the idle bar does is shield the plug element from fuel spray, helping it stay "lit" at low rpm. The idle bar is a small bar that runs across the tip of the glow plug, over the element.
Fastsky 06-04-2003 02:46 PM
idle bars...
I have done a lot of searching in the past on this subject and I have had both kinds of glow plugs.
In general the engine will run smoother and be more reliable by using the plug with the the bar and thats the only kind I use now.
:D
Joe Ortiz 06-04-2003 02:54 PM
Glow Plug Question
Will these plugs with idle bar work in any two stroke or just the lower end kind, how is the performance?
Live Wire 06-04-2003 03:08 PM
Glow Plug Question
Joe
The plugs will work in both, watch there is to different lengths of plugs long and short, There are F4st and 2st plugs in different heat ranges. There are a lot of LHS in Denver that can help you out or contact a club near you. Larry
Joe Ortiz 06-04-2003 04:13 PM
Glow Plug Question
Thanks for the replies guys.
Joe :)
