RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   CONVERTING KADET TO ELECTRIC - Project completed (https://www.rcuniverse.com/forum/beginners-85/8329739-converting-kadet-electric-project-completed.html)
shd3920 01-08-2009 06:44 PM
RE: CONVERTING KADET TO ELECTRIC
1 Attachment(s)
Well, I managed to get all the blindnuts into the firewall with an extra long screw. Now how can I get the glue around the blindnuts for the extra security? They are well into the tank area now and I can not get to them with a long stick or finger. Is it OK to just let the teeth of the blindnuts secure them? I mean, when I bolt the motor on they will pull the blindnuts deeper into the wood and I don't see how they can pull out, especially if I use threadlock.
Here are a couple photos of the spacers, without motor for clarity.
mclina 01-08-2009 09:51 PM
Good job. I wouldn't worry about glueing the back of the blind nuts. The tension will hold them in the wood, and there's not a lot of vibration from an electric motor. You should be fine.
shd3920 01-08-2009 10:38 PM
1 Attachment(s)
I ended up having to cut open a spot on the front to get to the blindnuts. Shouldn't be a problem covering it back up.
I need to know, how does the right thrust and down thrust look to you? Too much?
I have four small washers on the top of the mount and one on the bottom?
I am thinking maybe remove two of the top washers to give it less down thrust.
Also, is there too much pressure applied to the nylon spacers? Should I loosen the bolts a bit or replace with brass?
txaggie08 01-09-2009 03:48 AM
only critique I can offer, next time slow down on cutting. If ou had been a little more neat with the, theres no reason you couldn't have salvaged the top deck and built a nice screw down access hatch with almost no work. beyond some gluing. you can still do it, your just gonna have to work at it now.
Slow down, Slow down, Slow down. I learned the hard way that going fast = ruining and airplane.
CGRetired 01-09-2009 06:32 AM
I converted a Sig Little Something Extra (LSE) a couple of years ago. I used similar nylon stand-off's to get the motor to fit with the proper clearance. And, it flew very nice. Only problem I had was remembering to raise the TX antenna.. [>:] You see, I had been flying 2.4 GHz all day with my Venus II and when I finally ran the battery down on that, oh, about 6 flights or so, I put it aside and got out the LSE. I pre-flighted the thing, got all set to fly, then set it down on the runway and pushed the throttle. Up it went, and away it went. Oddly enough, I had throttle but nothing else. So, I pulled back the throttle and watched the thing glide into the woods. I eventually found it, though, with only a broken prop, so I was lucky.
This has nothing to do with the thread, but thought you may enjoy.. ?? reading about how dumb we can be.
Anyway, those standoff's look great. I also see the thrust angles follow the firewall, so it should fly very well.
CGr.
mclina 01-09-2009 09:31 AM
To follow up a bit on what was said about a hatch - are you planning for a battery hatch? Or are you planning to remove the wing every time you change batteries? I remove the wing on my Magic every time, but it's a bolt on. It does have a hatch, but it's held in place with wood screws, not magnets, and it's harder to open than the wing.
I did buy a set of magnets, I just haven't installed them yet.
The motor installation looks great.
CGRetired 01-09-2009 09:33 AM
Yeah, and also allow a path for air to flow over both the motor and the esc. The exit hole should be at least 1.5 times larger than the entrance hole to allo full and free movement of air over these components.
shd3920 01-09-2009 09:44 AM
1 Attachment(s)
ORIGINAL: mclina
I am not planning on a battery hatch. IMO not worth the work, I will simply remove the wing.
Are you sure the down and right thrust are OK? I think the down thrust is too much. As you can see in the photo it is more than what it was with the glow engine. I am going to remove two washers from the top of the motor mount and check again.
shd3920 01-09-2009 09:46 AM
ORIGINAL: CGRetired
I still have the cowl for the plane, so that leaves the motor fully exposed. The ESC will be with the servos, so I can not make any openings underneath the wing saddle.
CGRetired 01-09-2009 10:05 AM
You will really need to supply some path for air to flow over the ESC. If that means drilling a large hole in the firewall, and opening up the fuselage behind the wing to allow the air to flow through, then so be it.
Obviously, it (the firewall) won't need to protect anything from spilled fuel or oil from the fuel engine.. so you can find a convenient spot to provide an inlet for air flow. The engine will most likely take care of itself because it IS exposed to air flows. If you don't provide air flow over that ESC, you may.. most likely will, fry that ESC.
Don't forget the original part of this thread when we discussed current draw levels (40 amp and so on). The large component are on what are called heat-sinks. This draws heat away from these large components but these things have to be cooled somehow. If you don't provide a way for air to pass through, this will heat up that ESC pretty good and, well, things happen pretty quickly after it reaches a certain temperature threshold.
CGr.
shd3920 01-09-2009 10:14 AM
ORIGINAL: CGRetired
CGr.
Thank you, I will find a place to drill a hole. Will underneath the fuselage be OK? How big does the hole have to be?
P.S: There is already a hole in the firewall that I needed to drill to pass the ESC through.
RCKen 01-09-2009 10:21 AM
Also, you might want to rethink the battery hatch as well. If you look at any of the plane being commercially produced for electric power these days they are all being provided with easy access hatches for battery access. And most all of them are being mounted with magnets so you don't have to mess with screws. While it may not sound too bad to say you'll remove the wing each time, I can assure you that it's going to get real old real quick when you get to flying the plane.
Ken
CGRetired 01-09-2009 10:25 AM
1 Attachment(s)
Well, consider the amount of air that you want to pass through. A straw sized hole, for instance (1/4 inch or so) is no where adequate. Take a look at the drawing and you will see what I mean for making a hole... and providing no obstructions for the air to pass through and around the ESC. The exit hole should be about 1.5 to 2 times the size of the firewall hole, but that's not a problem, simply put a hole in the fuselage on the bottom. To make sure it does not rip out the covering, put some thin balsa to "support" the hole back there.
CGr.
CGRetired 01-09-2009 10:28 AM
As you can clearly see by all the advice, ideas, warnings, and so on, that we've given you, converting glow to electric has a lot of pit-falls and clearly has some hidden problems, issues, that really must be addressed. It is fun, yet at times frustrating, and the end result is usually worth the effort (you get some satisfaction that the thing flys great, knowing that you did it right).
And to add to what Ken said, you get a 10 minute flight, then what.. take the thing apart to REMOVE (yeah.. remove because if using LiPo, it really must be charged outside the aircraft and in a location that is not indoors, in your car/truck/SUV/whatever.. the danger of fire is real with LiPo's) the battery pack for recharge? Ok.. wait an hour (quick charge at 1C will take an hour) to fly again? I don't think so.
So you may want to get a second battery pack, and provide a hatch for access to the battery pack to swap it out with the freshly charged pack.. and charge the first one while flying with the second pack, and it goes from there.
CGr.
RCKen 01-09-2009 10:34 AM
To back up what CGRetired is saying. Cooling is absolutely essential in these electric planes. Especially since you're on a tight budget. This also includes what we were talking about earlier about having a large enough ESC (which you are getting). When an ESC is overloaded or is too hot you're not going to get any warnings about it. Rather, the ESC is simply going to fry and die!! And then you're going to have to replace it, no if's, and's, or but's. So it's better to take all the precautions now and get a large enough ESC and provide the ventilation BEFORE you start flying the plane.
I've seen many ESC's die in operation. They simply just quit working and the plane is landed dead stick.
Ken
CGRetired 01-09-2009 10:36 AM
Worse than dead-stick if using the BEC version of the ESC.. if it frys, well, no servo control and, well, the end result is fillling that trashbag you may have brought with you.
CGr.
RCKen 01-09-2009 10:42 AM
ORIGINAL: CGRetired
CGr.
Good point CGr. I forgot to mention that!!!! Sorry, not enough coffee yet this morning. :eek: Might be time to go make a cappocino!!! :D
Ken
shd3920 01-09-2009 12:01 PM
1 Attachment(s)
I have everything together to see what it looks like.
photo 1, 2: full body view
photo 3, 4: closeup
photo 5: side view to check down thrust
photo 6: top view to check right thrust
photo 7: radio compartment
shd3920 01-09-2009 12:08 PM
1 Attachment(s)
With cowl. Remember this was originally glow power, that is the reason for the cutouts on the cowl.
photo 12: I need to trim some more of the cowl, too close to the prop.
Now that I have the rough idea of the look I can work on the hatch cover, make the holes in the firewall and fuselage for the ESC.
But now with all these mods it will not be a glow plane again, but I don't mind.
mclina 01-09-2009 12:59 PM
It's looking good. I think you have a bit too much foam rubber in there to allow for airflow.
In my electrics, I just stick the esc and RX to the side of the fuse with double sided tape. They don't need foam for vibration protection like in a glow plane. My RX is probably more vulnerable in a crash, but I don't plan on crashing :D.
Maybe you can fabricate a little air scoop to go over the hole you cut in the top of the fuselage.
You are definitely getting there. Good job.
CGRetired 01-09-2009 01:23 PM
Yeah, I didn't notice that hole in the top. You could put a little scoop to the rear to guide air in there and over the ESC. And, as Mclina said, you should remove some of that foam to allow air to pass through.
You may also be able to re-fabricate a cowl and pretty that up. I've seen some pretty impressive cowl's made from a plastic 1 liter Pepsi (or Coke..ha) bottle. You can cut it to shape, then spray the inside with spray paint.. will look great from the outside and will help cover up that big area over the motor.
CGr.
shd3920 01-09-2009 02:01 PM
ORIGINAL: CGRetired
. . . You may also be able to re-fabricate a cowl and pretty that up. . .
CGr.
Can I find a replacement cowl for the Kadet Mark II and re-fabricate a new one specifically for the electric?
shd3920 01-09-2009 02:04 PM
ORIGINAL: mclina
Yes I agree, I am now doing a hatch at the bottom of the fuselage for the battery.
Will do. I thought electrics needed as much vibration protection. Thank you for clarifying that.
shd3920 01-09-2009 02:12 PM
1 Attachment(s)
Opened up the bottom front of fuselage for the battery hatch. Could not do it on the top as there are too many wood braces I added for strength.
Removed the tank tray as I needed more room for the battery placement. Will now be building up a battery tray, but first lunch.
CGRetired 01-09-2009 03:51 PM
That's fine. Now fabricate something to hold the battery pack in place. Use velcro and a slide-in something or other that you can mount the battery in place.. and DON'T ALLOW IT TO MOVE FORWARD OR BACKWARDS!!! Don't glue anything in to solidly until you are ready to. You want to make sure the CG is right (remember my original post).
About the cowl.. you may be able to get something. Look up the model in Google then go to whatever manufacturer makes the thing and see if they have one. But, fabricating something, such as out of a 1.5 liter plastic bottle.. hey, a plastic milk carton might work too.. same shape.. anything that is light then fabricate it to fit, then paint it from the inside. Remember the vent holes.. :D
CGr
