RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Help with speed... (https://www.rcuniverse.com/forum/beginners-85/834140-help-speed.html)
midnitedew 06-05-2003 01:53 AM
Help with speed...
hello, i have an aerobird and a firebird II, now i can fly these plane great... what im wondering is, how are the GWS airplanes speed compared to these 2 planes? i was thinking about getting either a GWS P-51 or a GWS Zero.... do these GWS planes fly about the same speed as and Aerobird slower or faster? will i need a bigger field to fly it in or the same area? thanks guys..
impulse 06-05-2003 02:58 AM
Help with speed...
They are way way faster so you will need a way bigger field.
MinnFlyer 06-05-2003 01:13 PM
Help with speed...
Hey Midnitedew, bring it out to our field in Willmar on June 28th. We're having a minnesota RCU fly in!
http://www.rcuniverse.com/showthread...31&forumid=225]
Montague 06-05-2003 01:31 PM
Help with speed...
I don't know about the p-51 and the zero, but I have the GWS A-10. It flys slowly, and is a bit marginal on power in stock form, but it is faster than the firebirds. I find it easy to keep in a small area, but I've been doing this for a while, other guys may not find it so easy. (I also find it flys inverted fairly well, but again, I've been doing this for a while).
If I were you, I'd find a club field to fly it at for at least the first few flights, then you can judge for yourself if you can keep it in your normal park.
