RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Mode 1 and Mode 2 ??????????????? (https://www.rcuniverse.com/forum/beginners-85/8406676-mode-1-mode-2-a.html)
bassfish 01-27-2009 07:25 AM
Hi Ya'll, Question, If "A" radio (mode 2} tx/rx have been installed in a plane to fly on channel 36, and radio "B' tx/rx(mode 1) has channel 14 crystals, would it be possible to remove the rx crystal (36) from radio "A" and install the rx crystal from radio "B" (14rx) into radio"A's" rx?
The reason that I ask is, I want a friend of mine that flys on mode 1 and I use mode 2 to maiden my plane for me. I say this is possible, he says that it is not! Please advise, many thanks,
Bassfish
rlipsett 01-27-2009 07:34 AM
RE: Mode 1 and Mode 2 ???????????????
as long as the manufacturer of the crystal are the proper ones for the type of reciver. in other words don't put jr crystals in a futaba. you may only swap rx crystals. since they are both low band crystal you should also have no problems if they are futaba recivers
bassfish 01-27-2009 08:03 AM
Thats what I think too! Thank ya!
rowdog_14 01-27-2009 09:25 AM
Keep in mind that mode 1 and 2 are totally different. I few my friends that had a different mode and I about crahsed his plane :) not real funny then, but it is now. I told him that I would stand beside him and talk him through it. He did great!!! As far as the crystals, I am with the other guy it should work with the same brand, even if they are different put it in and do a very long range check.
FILE IFR 01-27-2009 10:02 AM
What MHZ are the radios? They need to be the same for crystal swaps. ... All 72 MHZ for aircraft.
HighPlains 01-27-2009 10:09 AM
You may have to swap servo leads around too.
JohnBuckner 01-27-2009 10:09 AM
Concerning the Rx crystal swap another factor you must consider is, are both Rx's of the same conversion type? single or dual conversion. You never mentioned rx brand or model.
FILE IFR 01-27-2009 10:26 AM
ORIGINAL: JohnBuckner
Good call John. I thought of that AFTER I submitted my post. :D
bassfish 01-27-2009 02:41 PM
Hi John,
The radios are Futaba 72mHz, both use the same model r/x's dual conversion.
>>>-> Bassfish
JohnBuckner 01-27-2009 03:29 PM
Then yes as the others have indicated the proposed switch is appropriate and should present no problem.
carrellh 01-27-2009 06:22 PM
ORIGINAL: HighPlains
No. The receiver channels are not affected by transmitter stick mode.
Campgems 01-27-2009 06:24 PM
Depending on the model Futaba receiver, it will work. However, if your reciever is one that works in only High or Low band, the two channels you stated will not work. 11 to 35 is Lo band and 36 to 60 is HiI band. It may work due to being on the cusp, but I wouldn't bet a plane on it. What model receiver do you have??
Don
scoeroo 01-28-2009 09:16 AM
Bassfish,
I have a complete buddybox set-up ,
Mode 1 & mode 2 8103 JR on 2.4GHZ if you are interested , $700 , ready to go.
Regards
bassfish 02-01-2009 06:01 AM
Sorry but I'm not interested at this time,
>>>-> Bassfish
