covering
I have been tolled to cover my plane (pt-40) to use Towercoat because it’s good and It’s inexpensive, some say use MonoKote because it’s strong others sat it’s hard to work with, some say ultrakoat is best. For a beginner what would be the best to use.
RE: covering
For a beginner I would use the towercotesimply because it is cheaper and you may have to take some off and do over.
RE: covering
Hands down - Ultracote
RE: covering
I tried towerkote first cause it was cheap, and I can see why.:D It did an ok job, but Ultracote is so nice and easy to work with. I like it so much better. I've covered 3 planes now, haven't used monokote yet but I highly recommend the Ultracote. Oh, towerkote is difficult to cut. Ultracote is like cutting wrapping paper, piece of cake.
RE: covering
I'd recommend Ultracote too. I'd suggest that it is the most forgiving product to use, so you are less likely to need to recover. ;)
-MA |
RE: covering
Stay away form Towercoat. There is a reason why it's cheaper. It's very difficult to work with and won't give you good results, and for a beginner it will be overly frustrating for you on your first covering job.
I use both Ultracoat and Monokote, but if asked which I prefer I would say Monokote. I get great results with it. For somebody starting out I would say Ultracoat is going to be a bit easier on the learning curve. Ken |
RE: covering
OK you guys I give up. Ultracote is the way to go. I was just thinking if he and never covered before will probably makes lots of mistakes, two rolls of towercote to one roll of ultracote. Funny I use ultrcote but the only thing I don't like is: only the white to my understanding come in greater length than 6' I like coverite and monokote for that reason.
RE: covering
Funny that I said towercoteI have never used it and was only thinking of the cost. I don't know if the stimulus package will help me buy ultacote or coverite. RCU should get it's share of 785 billion.
RE: covering
Gene,
Yes, the ultracoat is more expensive than the towerkote. However, with ultracoat you can up it up and pull mistakes out and then reapply the covering. With towerkoat once you make a mistake it's premenant. I used Towerkote I gave up on it and threw away what I had left. I wouldn't even give it away it was so bad. I wouldn't use it again if I was given it free!!!! [:'(] Ken |
RE: covering
I don’t think the $16.00 ultracote is worth the price! I would rather take my time and use TowerKote for half the price.
thanks for the replies |
RE: covering
ORIGINAL: wzak29 I don’t think the $16.00 ultracote is worth the price! I would rather take my time and use TowerKote for half the price. thanks for the replies Ken |
RE: covering
Remember you get what you pay for!!! I use to be cheap and when it's all said and done you will land up spending more than you bargined for. No more! Use the Ultracote. I had not built anything or covered anything for 30 years. I built my TF Arrow and covered with Ultracote and it came out really nice.
chopper |
RE: covering
There is an old saying "only the rich can afford the inexpensive, because you have to replace it so often"
RE: covering
ORIGINAL: wzak29 I don’t think the $16.00 ultracote is worth the price! I would rather take my time and use TowerKote for half the price. thanks for the replies It's not that you need to take extra time, its that the quality is not nearly as nice. The wrinkles don't come out as well, really hard to cut, it's thinner and just sucks compared to ultracote. Do what you want though, just please post pics of the work when you're done.[sm=wink_smile.gif] |
RE: covering
1 Attachment(s)
Please use Ultracote, the extra cost is well worth it, and I am sure in the end you will be happy you did.
Here are my PT-40s that I covered in Ultracote. Yours can come out just as good. |
RE: covering
shd3920 Nice looking planes!
I trust the opinions in here so even though I can’t really afford ultracote I will use it. Were can I get a good deal on ultracote and a sealing iron Tower hobbies don’t have ultracote. Thanks for all of the good advice. |
RE: covering
ORIGINAL: wzak29 Tower hobbies don’t have ultracote. [link]http://www.horizonhobby.com[/link] or you can buy both Monokote and Ultracoat here [/link]http://www.advantagehobby.com[/link] Ken |
RE: covering
thank's RCken
What I saved on a sealing iron at http://www.horizonhobby.com made up the difference in the price of ultercote. |
RE: covering
You will be very happy with your decision to go with Ultracote.
chopper |
| All times are GMT -8. The time now is 02:12 AM. |
