What To Expect From A 4-Stroke
I'm building a Great Planes Gee Bee and I'd like to go with an OS 120 4 stroke but I know nothing about 4 strokes. Are they more trouble than 2 strokes? What about valve adjustments and such? I'd hate to have to send the thing back to the factory everytime I have a problem. (My other option for this plane is the OS 91 2 stroke)
RE: What To Expect From A 4-Stroke
It is best to tune a 4 stroke with a tachometer; the variation in pitch from lean to rich is not as noticeable as a 2 stroke (I've not yet fired up my first four stroke, but did work with my trainer on his and got a little experience).
Read the instruction manual. If any adjustments need to be made, they are not difficult, and the engine comes with a gauge and the tools to do the adjustments. OS four strokes have the reputation of being very easy to run, and running right out of the box. I wish I had one (in the Super Stearman I don't yet have). I say get the four stroke, and in the mean time download the manual and read it a few times. I love OS engines and really can not wait until (they come out with a 1.50 four stroke and) I have one. |
if you bought a brand new engine....you shouldnt have to mess with anything other than the carb like you would on a 2 stroke the valve lash should be fine factory,,,, the key IMO opinion to get that put put put put idle , is to set the low end right on....to rich and will idle rough, too lean and the idle will fade, and die when you try to throttle up
Good advise so far. I'm a 4 stroke nut. Currently have 11 of them. I'm trying to get a trainer ready to loan to one of our guys and it has a 2 strokd 40 one it. None of my four strokes have been as difficult to tune as this 2 stoke is. It is just tempermental.
I've been flying the four strokes for almost four years now. I've checked the valve lash on a couple, but have yet to have to adjust one other than the Saito 45 I rebuilt. Reasonable good fuel and glow plug and a proper tuned carb and it's like jumping in your car. Hit that starter and away you go. Don |
You'll love the 4-strokes. The mixture adjustment is no different that a 2-stroke other than it can a little more difficult to set "by ear". Once it is set you will likely never have to touch it unless there is a big temperature change. Best part is the great sound though.
Many people claim that you need really high nitro content fuel but I run 15% Cool Power in all of mine and they run great. I've also never found tight valves on one yet but if you have a basic understanding of engines whether it is from working on cars, bikes, mowers or whatever, you'll have no trouble maintaining an RC 4-stroke. |
ORIGINAL: gaRCfield It is best to tune a 4 stroke with a tachometer; It is never a good idea to tune an engine with a tach. 4-strokes are no more difficult than a 2-stroke, but there are two rules: 1) you MUST use a 4-stroke glow plug. 2) they run better with 10 - 15% nitro. Aside from those two things, they are just like a 2-stroke. Get one, you'll love it! PS, as far as adjusting the valves goes, I have been using 4-strokes almost exclusively for about 20 years and have needed to adjust valves once |
ORIGINAL: MinnFlyer Two words - B. S. It is never a good idea to tune an engine with a tach. 4-strokes are no more difficult than a 2-stroke, but there are two rules: 1) you MUST use a 4-stroke glow plug. 2) they run better with 10 - 15% nitro. Aside from those two things, they are just like a 2-stroke. Get one, you'll love it! PS, as far as adjusting the valves goes, I have been using 4-strokes almost exclusively for about 20 years and have needed to adjust valves once Most people simply cannot tune a 4-stroke by ear. Some of you guys have a problem with that for whatever reason, and can't seem to accept it. Why? You're not helping anyone by doing that. |
ORIGINAL: MinnFlyer ORIGINAL: gaRCfield It is best to tune a 4 stroke with a tachometer; It is never a good idea to tune an engine with a tach. I am not trying to start an argument or anything, just curious as to the reasoning behind your statement of it is never good to tune with a tach. |
I've got lousey hearing, but even I can hear when the RPM start to drop.
What I HAVE seen is people throwing a prop because they are trying to hit 11,000 RPM with a 4-stroke, OR the 16,000 RPM their manual says their 2-stroke has it's highest horsepower at. Allfat, the way you are doing it is correct, but too many people use a tach to hit a "Target" number - which is NOT a good thing to do. |
ORIGINAL: MinnFlyer I've got lousey hearing, but even I can hear when the RPM start to drop. What I HAVE seen is people throwing a prop because they are trying to hit 11,000 RPM with a 4-stroke, OR the 16,000 RPM their manual says their 2-stroke has it's highest horsepower at. Allfat, the way you are doing it is correct, but too many people use a tach to hit a "Target" number - which is NOT a good thing to do. I use a tach with my 4 strokes to make sure I'm NOT exceeding a "target" number with any given size prop. However, once you become familiar with your engine/prop/fuel/plane setup then the continued regular use of the tach will not be necessary. Most 4 strokes are the "set & forget" type of contraptions [8D] |
I've never used a tach on any of my engines, and never had a problem with power. Save your money.
NorfolkSouthern |
I've got a tach (for experimenting with fuel mixtures, prop sizes etc) and I've never even thought of using it to tune my 4 stroke 1.20 ASP, nor do I have any idea why anyone would need or want to. If you can tune a 2 stroke by ear you can do a 4 stroke too, and trying to tune an engine to get the last n'th degree of revs out of it is asking for a dead engine. Peak the revs out by ear (surely you can tell when an engine's getting faster or slower by the sound?) then back it off a few clicks, make sure it's running smooth, then leave it alone and you'll have a reliable, strong engine that'll run for years. Remember, if it aint broke, don't fix it!
As for valve lash the only time I've had to adjust mine was when I pulled the engine down to check for a bent crank after a somewhat vertical "landing", however from having worked on old cars for years I can tell you that it's worth taking ten minutes to look at the valves once every twelve months or so, just to stay within tolerances. It's a very simple job that won't even need the cowl on your plane removed (except for the few planes where the engine's completely encased), and it'll make you feel like a real mechanic and impress the pants off your friends at the club who only own 2 strokes when you casually mention "oh I checked the valve lash the other day, it was a few thousandths of an inch out so I tweaked it - runs great now". :D Oh and before someone talks you into buying OS because they're "better", my ASP cheapie 4 stroke runs as well as any OS one I've seen, costs half the price, and is tuned exactly the same way (it is after all a direct copy of an older OS engine). Magnum engines are also great value and are identical to ASP's. |
ORIGINAL: Sandmann_AU If you can tune a 2 stroke by ear you can do a 4 stroke too |
ORIGINAL: MikeL ORIGINAL: Sandmann_AU If you can tune a 2 stroke by ear you can do a 4 stroke too |
A club of 230 special people, eh?
You're right, it's not rocket science. Pretending that using a tach is hard to do certainly doesn't do anyone any favors. Perhaps you haven't used one? You simply hold it behind the prop, tune to the peak RPM, and then drop it 300-500rpm. It's simple, precise, and very safe. Why some of you become almost militant about this baffles me. |
I only get upset about it when people insist that using a tach is a MUST for tuning a 4-stroke.
Using a tach is a great way to tune an engine (2 or 4-stroke) IF it is used properly. But too often it is not used properly, and just as often, the person using it could do it just as easily by ear. For those who say, "You need a tach to tune a 4-stroke", I say, "Then you had better use it on your 2-strokes as well" If you can tune a 2-stroke by ear, then there is no reason why you couldn't tune a 4-stroke by ear. |
I am using OS Saito and YS fourstrokes. They all seem to be a set and forget when it comes to tuning. The OS is the oldest with the most run time on it. I quit counting past 25 gals. It has required the most valve adjustments,but only 2 times a year. That takes just a few minutes and it very easy to do. It is still one of the most realiable though. It has a very low idel and has never deadsticked. Some of the the guys I fly with us OS 120's and the really run great. Once you start using 4 strokes you will really like the smooth power and performance of them. I havn't had a 2 stroke since I sold my trainer, and do not miss it.
ORIGINAL: MikeL A club of 230 special people, eh? ORIGINAL: MikeL You're right, it's not rocket science. Pretending that using a tach is hard to do certainly doesn't do anyone any favors. Perhaps you haven't used one? You simply hold it behind the prop, tune to the peak RPM, and then drop it 300-500rpm. It's simple, precise, and very safe. ORIGINAL: MikeL Why some of you become almost militant about this baffles me. |
What To Expect From A 4-Stroke .........
A lot less oil to wipe off your plane after a flight. Can be more expensive to repair than a 2 stroke in case of a crash. They sound a lot better than a 2 stroke. |
1 Attachment(s)
Hi!
Four strokes are as easy to set by ear as any other engine. In pylon racing I think all seasoned pilots set their engines by ear! Have never seen one set their engine by a tach on the starting line. A Tach is useful only when you file and modify a prop and want to compare to other props and try to reach a certain rpm.It's also good to have a tach when you want to set your engines on a twin to rew approximately the same (which isn't really necessary) before take-off. If you haven't flown a four-stroke before... then for heavens sake try one out in another airplane before trying it in the Great Planes GEE-BEE R-2. I have flown the GEE BEE R-2 now for 4 years and it is a very easy airplane to take off and fly....but, the landings are very, very demanding (that means difficult) to accomplish without flipping over. Part of the problem is the high weight! Part is that the Great Plane GEE BEE R-2 wing is set +6 (stab 0) which means that on landing with a high angle off attack the wing stalls early (which means it will snap just before touch down). The remedy is to build it light! a 20cc four-stoke is fine but not anything bigger (heavier). I have mine powered by a MVVS 15cc (.91) two-stroke with custom made silencer running a 15x4 APC and a Tettra 15oz "bubbleless" tank. All up weight is 5000g (around 11 pounds). Before flying a plane like the GEE BEE R-2 it is good to try out several other fast flying/aerobatic airplanes so that you are used to what happens with high performance airplanes (Why not flying Q-500 racing). Other wise the first flight of the GEE BEE will not end so well... |
What to expect from a 4 stroke.............like everything else in this hobby, expect difference of opinion! Gotta love it.
1 Attachment(s)
Dgremlin Once you have a 4 stroke, that's all you are going to want to fly. I love my Saito 82 and I used a Tach during breakin. This is my first 4 S. and compared to a NIB K&B 61 from the 80's i'm trying to breakin, it's by far much better technology. Bob |
ORIGINAL: MinnFlyer If you can tune a 2-stroke by ear, then there is no reason why you couldn't tune a 4-stroke by ear. |
ORIGINAL: dignlivn Once you have a 4 stroke, that's all you are going to want to fly. |
Chuck, A 4 stroke Gas is on my Wish list :D Bob |
No, I'm not an MD, but if you can tune a 2-stroke by ear, but not a 4-stroke, maybe you need to get your hearing checked by one?
Well Minn, I have a YS 1.20NC that will kick your mule if you try to tune it by ear. You just can't hear a change?? Not only can't you hear the change but the high end needle can be twisted a lot before you hear the drop. Why is this?? I don't have a clue. It's the only engine I have that is like that. Same thing with the low end but the old NCs used the pressure screw to adjust the low end, no low end needle on this one. All my other four strokes are easy to get the tune by ear or at least close. I still use my tach a lot when setting up a new engine and testing props. BACK to the question. About the only reason for using a four stroke is the noise and they have a smoother power band through all the RPM range and swing a bigger prop because of the torque. To maintain mine I just check the valves once a year and adjust if needed. All but one of my four strokes is a pumper of one type or another. With a pumper you can get away with installing your fuel tank any place you want in the plane. There are a lot of other little reasons for a four stroke but for the most part it's the cool factor.
ORIGINAL: MinnFlyer No, I'm not an MD, but if you can tune a 2-stroke by ear, but not a 4-stroke, maybe you need to get your hearing checked by one? You guys make me laugh. How many of us love 4-strokes because they don't make the same sounds that two-strokes do? Quite a few of us, I'd imagine. Part of that is that the pitch changes aren't nearly as perceptible. Again, if you say you can hear the difference, that's really great for you. I'm proud of you. You deserve a gold star. Most of us, however, can't do that. For whatever reason you have difficulty accepting that. I'm not sure why. If you can pick out exactly when a 4-stroke is peaked, that's great. If your ears will tell you when it's richened 300-500rpm, that's great, too. My ears don't work that way, so I use a simple, inexpensive tool. |
Well, here's what I can tell you... I fly all over the country and I have never seen anyone tune an engine using a tach. So I would have to believe that MOST people do not use one.
Sure, there may be a few people here and there that do, but I've just never seen it done. |
Really? So I suppose all of the discussion about it here over the years is just... imaginary. I need my ears checked, you need your eyes checked... aren't we a pair?
I think it would be a good topic in the engines forum - see how many people use a tach compared to their ears.
I'll be gland when the snow is gone and you guys can do some flying and improve your atitude a bit. I think cabin fever is setting in real bad:D
most of the guys who tune there 2strokes at our club use the pinch test to tune not by ear, this same debate was pummeled to death a couple of months ago and its now resurfaced again, with the same arguements against a tach.no real reason not to use one just "you don't need that kid" and some chest pounding about how they can do it without a particular tool, a bit goofy really[sm=spinnyeyes.gif].
I use a tach on my 4st engines which are the majority of the type I happen to have, all the guys at our field who have used 4st engines recomended using it and its a handy tool it really eleminates the guess work out of tuning your engines, something I do every flying session( adjust the high speed needle) by peaking the RPM and backing it off a few hundred so when the prop unloads it doesn't overheat the engine. I pile that sort of advice into the same junk bin as the,"you don't need that engine manual just do it my way and you will be fine son" mentality,I call it poor . for a beginner just starting out get a tach. use it familiarize your self with the tuning and running procedures, learn the engine inside and out and if you don't need it later pass it on to the next guy/girl who is just starting to learn the process of tuning there engines. 4strokes are not cheap, and a extra 15$ is worth it to me, and the planes I happen to fly with them, there not cheap as well . valve adjustment kits don't come with OS engines now, there 12$mine sits in the corner 11 1/2 months a year, I get more use from the tach for sure. I have checked the valves on my newer OS 91's and they have all held there adjustments even after break in runs, just like GB stated once a year is about all they need just to be sure. 4st burn less fuel and are cleaner,alot less slime and the small amount of oil is burned more thoroughly than on a 2st, I like that as well:D matter of fact I am going over the fleet now, doing my pre season clean up, valve checks, and EZ fueler maint. checks for flying season since we just got a new field the only ones that needed to be adjusted were a couple of the engines I got off ebay after adjusting they ran great,(my gain). |
I always use a tack on my 4-strokes.
Once I hit a certain rpm I take my transmitter and shift from low to high rates. :) |
ORIGINAL: Campgems I'll be gland when the snow is gone and you guys can do some flying and improve your atitude a bit. I think cabin fever is setting in real bad:D The attitudes being expressed in this thread are hardly conducive to fostering goodwill & encouraging beginners to stay involved in this wonderful hobby / sport / past time [8D] |
I think the learning curve for the four strokes is a little bit different than the two strokes. I tended to go too lean on the top end when learning the four stroke. When I let that sink into my thick noggin, tuning became a breeze. The four stokes are fun. Good luck!
I like them all if they say ys . There is only one kind of good model engine the one that runs. I LOVE ENGINES WITH PROBLEMS . It dont matter if there four strokes or two and gas .I like buying them when no one know how to run them. A os four stroke is good choice and yes you need a tach for tuning. I WORST THING TO DO IS FLOAT A VAVLE DUE TO IMPROPER TUNING! And to small of a prop! a os 120 will swing a 15-8 ,15-10 ,16-8. They are a fine running engine.
ORIGINAL: TROUBLED 61sf and yes you need a tach for tuning. I can't believe there are so many people out there whose hearing is that bad |
You could, of course, just accept that there are many of us who can't do what you say you can do, Mike. What is really so hard about that? I'm truly at a loss for your inability or unwillingness to understand that. Which of the two is it?
These threads get pretty stupid sometimes, with people taking their arguments to the extremes simply because they can't hear what others are saying. My ears can't detect small changes in the speed of a four-stroke. They can with a two-stroke. Can you hear me when I say that? Can you listen to me, rather than attempting to tell me that I'm wrong about my own senses? There's no need to take this argument to the point of absurdity. Pride shouldn't get in the way of hearing what another is saying. |
What bothers me is not that some people can't hear the difference. Ok, I'll accept the fact that some people need a tachometer to tune their 4-strokes.
What bothers me is when someone tells someone else who may be a little gun-shy about buying their first 4-stroke that they MUST buy a $30 piece of equipment to go with it or they won't be able to tune it - even though everyone I know does not need one. Now you are the first one to say that we are not all alike, yet you jump on me when I tell these same people that they do NOT need to spend that extra money, nor do they need to learn a new technique to tune their engine. But you stick to your guns defending your position. How about this: Tune your 4-stroke the same way you would tune a 2-stroke. If you find you can't hear the difference in RPM (which some people can't) you may want to consider getting a tachometer to help you out. |
| All times are GMT -8. The time now is 07:28 PM. |
