Control Surface Hardware
Hi again everyone. I have another build question. Should I use the plastic hardware that came with my ARF to connect the rod from the servos to the control surfaces or buy metal ones? Does it really matter, is one better than the other? Thanks again.
RE: Control Surface Hardware
The hardware that comes with an ARF is typically 2mm and the metal stuff like Dubro or Great planes is 2-56
Its all or nothing. If you are going to use the metal clevises you will need new 2-56 rods too |
What kind of ARF is it? If it is from Great Planes, Hangar-9, Sig, World Models or another reputable manufacturer then go ahead and use it. It is designed for the job and will be just fine. Some of those manufacturers also use SAE sized hardware (I know GP generally does) so you could replace it with metal stuff if you really wanted.
If you have one of those el-cheapo planes with instructions that don't make sense then you'll likely want to ditch all the hardware in favor of some quality stuff. |
It is indeed one of those cheap-o brands. It's a China Model Productions P-51.
I have no personal experience with that manufacturer so I really can't comment on their hardware. If you are concerned though it can't hurt to change it.
there are a lot of CMP arf's built over in the warbird forum, you may ask those guys
ORIGINAL: w8ye The hardware that comes with an ARF is typically 2mm and the metal stuff like Dubro or Great planes is 2-56 Its all or nothing. If you are going to use the metal clevises you will need new 2-56 rods too http://www3.towerhobbies.com/cgi-bin...&I=LXWL54&P=SM Bruce |
The hobby shop down below the house has both 2mm rods/hardware as well as 2-56 and 4-40
| All times are GMT -8. The time now is 07:56 PM. |
