2.4 GHz systems
In the world of Tx's, is the range(distance) of the 2.4GHz systems more, less, the same as the 72 MHz systems?
Thanks! |
RE: 2.4 GHz systems
Technically, shorter. The practical part of it is, well, if you can see it, you can fly it. But, this all depends on the type of a receiver you are using. If it is a park flyer type receiver, well, your range is restricted. If it is a full-range receiver, then you can pretty much compare it to the 72 MHz systems... for all practical purposes. As I said, technically, no. The range is shorter (pretty much line of sight).
CGr. |
RE: 2.4 GHz systems
You can fly till you won't see the plane and you will still have control, so don't worry about it.
RE: 2.4 GHz systems
Unless you get behind a solid object, but then if you do that it won't matter anyway.
RE: 2.4 GHz systems
Like I said, if you can see it, you can fly with it.
CGr |
| All times are GMT -8. The time now is 11:27 AM. |
