Throttle Cable
Hi,
I am about to install my first throttle cable. I have always used a wire in the past. Is there anything special I need to know or do? Do I solder the ends to revent unraveling? Thanks, KW_Counter |
RE: Throttle Cable
Solder on brass threaded coupler or similar device. Use plastic to plastic connection on the carb arm also. Bob |
RE: Throttle Cable
I always Solder on my threaded end that will hold the ball link set up on the carb first.
Then i Mark the length i need to the servo. Mark it and solder that end abit past what i need. Then i cut the remainder off with a dremel. Ive never had a problem with the flex cable unraveling by doing this. |
RE: Throttle Cable
Make sure you tie down the tube that the cable is in so that it moves the cable instead of bowing it. Probably not a big problem on a carb since it doesn't have much resistance. I had a problem with it bowing a lot on my float plane rudder.
RE: Throttle Cable
I only use cables for all my throttle and steering applications. And I use the EZ Connectors for both throttle arm and servo ends
http://www.horizonhobby.com/Products...?ProdID=DUB121 Work great. |
RE: Throttle Cable
This cable is using EZ Connectors on both ends.
Both control arms are plastic. I'm not worried about RFI. I am worried about unravelling. The tube seems pretty secure but will watch for problems here. Thanks for the suggestions. KW_Counter |
RE: Throttle Cable
Hi
I like the braided cables too. Solder the area you wish to cut BEFORE cutting, I use a cut off wheel in the dremmel. no fraying at all. The smoother the cable or any control rod, wire, etc, moves the less drain on the battery you'll have. |
| All times are GMT -8. The time now is 08:15 PM. |
