Twin ESC's?
Hi, Being a newcomer to electric flight, can someone answer what might seem a stupid question to the enlightened. I've got a Cessna Skymaster and I'm thinking of going electric with it. As it's a twin motor, do I need 2 ESC's or can I use just the one? Thanks.
RE: Twin ESC's?
carl,
if its 2 brushless motors then you need an esc for each motor. and then you need to disable 1 of the bec's (battery eliminating circuit ) on 1 esc. very easy to do just remove the red wire from 1 of the esc's (slip the pin out with a small flat screwdriver) and tape it back , that way you can use it again by simply putting it back in. or use a small extension and clip the red wire on it and tape it back. much better than cutting the esc wire :) bassman |
RE: Twin ESC's?
I have an electric Catalina. I use 2 ESCs. They have a "Y" cord to the RX and a "Y" cord to a single battery pack.
RE: Twin ESC's?
When using 2 ESCs please buy something branded if you can. I have seen cheaper ESC not in sync when used in twin power set ups. You will get less power in one motor compared to the other. :)
RE: Twin ESC's?
Cheers my man. Very much appreciated.
| All times are GMT -8. The time now is 08:38 AM. |
