RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   fitting Cherokee cowl / muffler ?? (https://www.rcuniverse.com/forum/beginners-85/8777187-fitting-cherokee-cowl-muffler.html)
Popriv 05-17-2009 07:12 PM
1 Attachment(s)
Working on this cherokee that I bought used over the winter.
It doesnt look like the original muffler? Would it have been blue like the engine?
There is no way this cowl fits over that muffler without cutting out the whole bottom corner of the cowl...???
Anyone have a picture of what this is supposed to look like?
Didnt appreciate the computerized radios until I started setting this up with an old futaba radio it came with...
Have to set up everything mechanically. good to do though.
Steve
redfox435cat 05-17-2009 07:23 PM
RE: fitting Cherokee cowl / muffler ??
nope that's your typical OS LA motor. It's what came with it.
ChuckW 05-17-2009 07:35 PM
Yep, you'll have to cut the cowl to fit around the muffler. Every blue LA engine I have ever seen had a bare muffler. I always thought it was a little goofy myself to do it that way but that's what they did.
DaveB 05-25-2009 08:26 AM
Is that the original engine?  From the looks of the cut out in the cowl, I am guessing there was originally a 4-stroke engine installed.  </p>
DaveB</p>
</p>
Popriv 05-25-2009 12:55 PM
ORIGINAL: DaveB
Is that the original engine? From the looks of the cut out in the cowl, I am guessing there was originally a 4-stroke engine installed.</p>
DaveB</p>
</p>
That might explain why the cown didnt have a cutout for the 2 stroke muffler?
I dont know the history of this plane.
I started the engine today and notices the firewall flexing. I got the NOGO from the gurus at the feild.. I agreed.
I'll have to remove the engine and double up the firewall.
Steve
jrcaster 05-25-2009 01:07 PM
I don't think it is a matter of doubling the firewall as much as it is re-gluing the firewall in.  Sounds like it had a rough landing and the firewall is loose.
jaka 05-25-2009 01:54 PM
1 Attachment(s)
Hi!
Tilt the engine cylinder to the left some so the silencer comes under the fuselage.
Then carve away some of the firewall and fuselage to have a space for the silencer. Use 0,4mm plywood , glasfiber and microballons to fill the area above the silencer using the silencer as mold.
Popriv 05-25-2009 04:18 PM
ORIGINAL: jrcaster
Looks more like the firewall cracked, the way it buckels. not like its come apart at the edge of the firewall. I have to inspect it closer. it wasnt obvious where the problem is.
The more experienced guys confirmed it has to be addressed.
ro347 05-25-2009 06:51 PM
now thatsa beatifully cut cowl~~~~~~
ORIGINAL: jaka
Hi!
