RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   spinner (https://www.rcuniverse.com/forum/beginners-85/8827528-spinner.html)
frenchdoor 06-05-2009 09:28 AM
spinner
<span class="Apple-style-span" style="font-family: Verdana; font-size: 11px; white-space: pre-wrap; -webkit-border-horizontal-spacing: 1px; -webkit-border-vertical-spacing: 1px; ">i have a plastic spinner and tried looking it up online..... and it is not on the plane yet but closed up.... (previously used) I was wondering how to get the spinner off of its base... i dont see any screws but the bottom has these little things that look like if pushed together the base would slide off??</span>
MinnFlyer 06-05-2009 10:17 AM
RE: spinner
Sounds like a Goldberg spinner.
There should be two slots where you can slide a screwdriver between the two pieces and pry them apart
brett65 06-05-2009 10:18 AM
RE: spinner
Carl Goldberg spinners are snap together, that may be what you have. There are several little slots that you slide a small screwdriver into and twist gently and the cone will pop loose from the base. The things on the bottom you are seeing are what holds it together, don't mess with them. Look for the little slots on the outside circumference of the base.
frenchdoor 06-05-2009 12:02 PM
RE: spinner
i tried doing as you said ... haha but it does not seem to want to come apart.!
brett65 06-05-2009 12:15 PM
RE: spinner
Post a pic of it if you can, but they do require a good bit of force. You won't break it, keep trying.
frenchdoor 06-05-2009 12:24 PM
RE: spinner
yeah that worked... I was afriad the plastic would snap if I tried too hard!
Thanks!
warbird72 06-06-2009 05:48 AM
RE: spinner
Place small flat screw driver in slot and pry each one of them...
