I Need a Tachometer, suggestions?
What tach are you guys using? Any big differences between the various brands?
Michael |
I have the hanger 9 digital mini tach. Works perfect, nice price. Now, if I can just decide on an loaded voltmeter, I'll be set.
I have a tach, and I even use it once in a while.
I'm curious, why do you feel you need a tach? Depending on your application, any of the low-cost digital units will work quite well. I have a 10+yr old Tower tach myself. |
Originally posted by cruzomatic I have the hanger 9 digital mini tach. Works perfect, nice price. Now, if I can just decide on an loaded voltmeter, I'll be set. I think Hobbico do a voltmeter in which the load can be swtiched on or off. |
Re: I Need a Tachometer, suggestions?
Originally posted by MSP1957 What tach are you guys using? Any big differences between the various brands? Michael It really depends on how much and where you are going to use it. If you think you are going to use it a lot and maybe in less than ideal lighting conditions then it might be an idea to splash out the extra on a TNC tach. |
I have a glowbee and no problems at all.
| All times are GMT -8. The time now is 11:07 PM. |
