HELP WITH MAKE AND MODEL
1 Attachment(s)
<span style="color: #ff0000">If anybody can helpI would like to know the model and make of this biplane, and also what size engine it would take? The wingspan is 65 inch for both the top and bottom wing. The fusalage length is 55 inches from the nose to the rudder.Please help me Idenifty this Bi-plane!</span>
RE: help with model and make
Goldberg Bucker
1.20 engine |
Thanks for your help. I am new to the airplane thing. If you have any advice or anything for me please notify me. Thanks
Hello fellow Tennesseein ( cant spell ), Welcom to RCU. Have you flown before?
ORIGINAL: wags1009 Thanks for your help. I am new to the airplane thing. If you have any advice or anything for me please notify me. Thanks I beleve HighPlains called it correctly and the full name would be Bucker Yungmeister. I think this airplane is appropriate for a 90 fourstroke. If you are new to the airplane thing then this airplane is totally unsuited for you to learn on. Working even with an instructor an attempt to use that airplane will only serve to stretch out your learning time slowing down progress. John |
RE: HELP WITH MAKE AND MODEL
I've got a half built one in the shop. A guy let me fly his about 15 years ago, and it is a very good design....for the advanced flyier. I had to get it after flying one, it's that good for sport acro. It glides better than the typical biplane due to the thin high aspect ratio wings. Here is the setup info for it:
http://www.carlgoldbergproducts.com/...ed/bucker.html Keep it for your third or forth model. |
65 inch wingspan bipe....you didn't say the weight but based on the wingspan I'd go with a 1.20...
| All times are GMT -8. The time now is 09:11 PM. |
