RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   ENGINE RUNNING BACKWARDS? (https://www.rcuniverse.com/forum/beginners-85/9093311-engine-running-backwards.html)
ddpc1963 09-13-2009 08:46 PM
I have a size .60 k & b that wants to run backwards. when it does run forward it seems sick and weak. Anyone know what is up with this?
Live Wire 09-13-2009 09:39 PM
RE: ENGINE RUNNING BACKWARDS?
What carb. does it have on it :eek: sounds like it is running rich. Let hand rotation to run.
millertym2000 09-13-2009 09:43 PM
Wanting to run backwards is a common thing, My 46ax does it all the time. Mine does it when I prime it to much before I start it. Yours sounds a little rich like Live Wire said, try leaning it out a little and see if that helps.
downunder 09-14-2009 03:01 AM
Usually it's a sign of overpriming but have you run this engine before? I'm not very familiar with K&B engines but I believe there was a reverse rotation crankshaft available for some. If it wants to run great in reverse then that's the likely culprit :).
RappyPilot 09-14-2009 08:25 AM
Every engine I have owned has done that at some point, specially when using a chicken stick. Does seem to happen when the engine is over-primed or running very rich.
If it does that, normally a quick jab on the throttle sorts it out.
I have come into the habit of starting the engine by grabbing the spinner and then smartly flipping the engine in the opposite direction (Clockwise)
Works like a charm and my engines never start backwards like that. Works on my .46 two strokes all the way up to my .91 four strokes.
ddpc1963 09-14-2009 11:51 AM
Thank you all very much. All answers seem to point to a rich mixture.I will check it out. Thanks again!
aerowoof 09-14-2009 03:28 PM
K&b did offer a reverse crank for this,the .40 and the veco .19 .Did you buy this used?
Live Wire 09-14-2009 04:38 PM
To think about it :eek: Clarence did reverse a couple 60's;)
ddpc1963 09-14-2009 06:48 PM
yes this was bought used
JOHNS3D 09-14-2009 11:22 PM
are you sure is not pusher engine??? i know is a stupid question...but maybe it can happen.
ddpc1963 09-15-2009 07:26 AM
I have never heard of a pusher before but I am new at this.hmmm
Live Wire 09-15-2009 08:16 AM
You never said which carburator you have. can you take a pic. of the motor and then we can tell. They put out the standard and the pumped engine and the carb's are different.
Larry K
JOHNS3D 09-15-2009 08:41 AM
ORIGINAL: ddpc1963
it can be 2 things here....your carb....or you got a pusher engine, that means that start in correct running and then change to push the air to the front, thats a "pusher" engine for airplanes that use the engine in the back, etc.
bruce88123 09-15-2009 11:18 AM
You can get a reverse crank for the K&B 61. I know, I have one.
bruce88123 09-15-2009 11:24 AM
ORIGINAL: Live Wire
Larry K
There were a variety of carbs offered on the non-pumped engines including Perry carbs. Perry carbs were also used on the pumped engines but were a larger bore I believe and a couple of different ones were offered.
http://www.mecoa.com/kb/ is the present manufacturer and "authority" these days and could help you sort out the engine if it comes down to that point.
Current Perry pumps and carbs can be found at http://www.perrypumps.com/prod01.htm
HighPlains 09-16-2009 12:10 AM
Just remove the carb and look at the crank to tell if it is a reverse rotation crankshaft. The crank opening will occur while the piston is moving up, usually about the point that the piston covers the exhaust. End of speculation.
ddpc1963 09-16-2009 07:06 AM
I WILL CHECK THAT. THANK YOU.
ddpc1963 09-16-2009 07:15 AM
I will try to get a picture of the carb and send it to you.It looks strange. It has a plate on the side about the size of a dime and a screw on the outter edge of it that does not seem to do much. None of my other engines have this set up.
HighPlains 09-16-2009 08:01 AM
That sounds like a Perry carb. Very good design at a time when many carbs were difficult to adjust and perform well. Does it look like the ones on this web page:
There is a small volume inside the carb that holds fuel, so it can run for a while when the fuel is disrupted from the fuel tank. And I belive there is also an internal fuel filter, which can clog up with conjelled oil. So a careful cleaning may solve your problems. It also depends on an O-ring or two. It's been a very long time since I've had one apart.
There was an article on the care and cleaning in RCM if you can find it.
PERRY CARB METERING SLOT, CLEANING, FOR WHAT IT'S WORTH, Smith, Jerry, Dec-95, 84
ddpc1963 09-17-2009 08:15 AM
1 Attachment(s)
some pics
aerowoof 09-17-2009 11:59 AM
ok that is not a veco it is a K&B sportster that has a remote needle valve that is not shown in the pictures.If you are just connecting the fuel tank to the fuel nipple on the carb you have no way of requlating the volume and it is real rich.you need to get the remote needle
SushiSeeker 09-17-2009 10:34 PM
I noticed in the picture the engine is stamped "Made in USA".
That's sadly a sure sign of the age of this engine.
downunder 09-17-2009 11:22 PM
For sure, it could be weeks old..... :D
http://www.mecoa.com/kb/aero/aircraft.htm
sportrider_fz6 09-17-2009 11:58 PM
ORIGINAL: SushiSeeker
I noticed in the picture the engine is stamped ''Made in USA''.
I just bought a K&B .65 a few weeks ago, brand new in the box, at a hobby store, it's made in the USA also. I may be buying more K&B products now, it's hard to find things made in the US anymore.
as far as the engine goes, the "dime" looking thing on the side is the low speed mixture screw. it only move 1/8" either way from center. it controls an eccentric that regulates the venturi on the carb
