Fuel Dot on Plane with a COWL (Not sure of Setup)
I have fuel dots on each of my planes except for my trainer. I really like using them so I don't have to remove the lines at the engine. So far I have not had a plane with a cowl, but now am building a Funtana S.40. In my other planes, I use a 3 line system and when fueling I remove use the fuel dot for filling with the pressure line off of the muffler for the overflow. How should I set this up on a cowled plane so I can remove the line from the muffler when I am fueling?
Any help would be appreciated, I would like to have the plane in the air this weekend. |
a "T"
Use a T fitting on the muffler line and plug it with another fuel dot.
Another option:
1 Line with clunk to the carb, 1 Line as overflow/pressure line to the muffler, 1 Line with clunk connected to the fuel dot for filling/draining. IF you don't happen to see the excess fuel in the overflow before it gets to the muffler, it isn't a big deal, you'll just waste more fuel. |
P51-B: Do you mean that I will see the overflow out of the back of the muffler? Reason that is ask is the way you describe the set up is exactly what I use. By your statement it sounds like you look at the tail end of the muffler if you don't remove the line to the muffler itself.
What I have seen is to bring the fuel line to a visible part of the plane then back "down" to the muffler. When you see the fuel in the line, it is fueled!
| All times are GMT -8. The time now is 12:16 AM. |
