RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Name this Plane (https://www.rcuniverse.com/forum/beginners-85/9283872-name-plane.html)
MetallicaJunkie 11-26-2009 11:52 PM
Name this Plane
1 Attachment(s)
I recently acquired this plane dirt cheap...The seller on Craigslist listed it as a Kaos, but i know better than that... Just by looking at it i can tell it is at least 20+ years old, it came with a ST Saturno 60, Rx and servos which i will replace with 821s that i had for a "spare" plane... All for 100 bucks
Can anyone identify the name of this model?
sorry for the horrible pics i took then in the evening with my cell phone.
aerowoof 11-27-2009 09:08 AM
RE: Name this Plane
noe ringing a bell but if its a 60 it 's probably pre 1980 if it is a non schnurle engine it would be pre 1976
KW_Counter 11-27-2009 09:12 AM
RE: Name this Plane
Metallica,
It may be the Bridi Kaos.
I have a similar looking plane and that is what
the people in my club said it was.
The current Kaos is a mid-wing while the Bridi is a low-wing.
Hope this helps,
KW_Counter
Gray Beard 11-27-2009 11:21 AM
RE: Name this Plane
1 Attachment(s)
This is a Bridi Kaos 60 size, I tried to get a photo of the same angle you are showing. I made some mods on this one though, I made a much longer fin and made the rudder bigger plus it's a tail dragger. Joe Bridi made several designs of this plane with slight mods plus Tower had the kits for a time and made some slight changes. I have some plans for some of his early designs and they all used the same wing but have a shorter fuse. Your plane may be one of the early designs?? Hard to tell from the photos. Also, most of the small pattern planes from the 60s through the 70s looked quite a bit alike, I built a Daddy Rabbit from 1966 and it may have shorter moments but it still looks a lot like a Kaos.
I went ahead and added a photo of the DR too so you could see what I'm talking about.
Lnewqban 11-27-2009 11:45 AM
RE: Name this Plane
MetallicaJunkie,
You could try to find a similar model at this collection of pictures of Classic Pattern models:
http://www.trentonrcflyers.com/pattern/patternk.htm
It seems that the wing is non-tappered, and that the vertical fin is swept back; not like any of the Kaos.
whatiwork4 11-27-2009 01:06 PM
RE: Name this Plane
the kaos has a double tapered wing as the one in the pic is constant chord.also has a thick airfoil more of a sport type design than pattern.
MetallicaJunkie 11-27-2009 01:07 PM
RE: Name this Plane
Ok thanks for the help guys, ill call it a Kaos then.... i cant believe the engine and plane are older than i am(30) It is in great shape. I think i might have a new favorite sport plane:D
nice site lnewqban
psuguru 11-27-2009 05:57 PM
RE: Name this Plane
ORIGINAL: MetallicaJunkie
nice site lnewqban
I've seen this model before and I think it's an old Top Flite kit.
Gray Beard 11-27-2009 06:21 PM
RE: Name this Plane
ORIGINAL: lnewqban
MetallicaJunkie,
I have never seen that site before, wow!! As I mentioned, there is form in function, as the years go by the planes may change but they always show there roots. I even spotted on of my planes in there that the photo was turned in by someone else. That was cool. I spotted another Kaos that belongs to one of the guys I fly with too. I put that site in my favorites so i can check out the way others have covered or painted there planes.
w8ye 11-27-2009 06:36 PM
RE: Name this Plane
Looks like a Sig KIWI with the ailerons not tapered at the tips
http://image2-9.rcuniverse.com/e1/fo...58/Ol31529.jpg
http://www.trentonrcflyers.com/patte...igkiwi4rcu.jpg
DaveB 11-27-2009 06:44 PM
RE: Name this Plane
Definitely not a "Kaos". As stated earlier, the wing is wrong. Also the horizontal stabilizer is very different from any "Kaos" I have owned or observed. Having said that, I don't know what it is.
DaveB
whatiwork4 11-28-2009 08:38 AM
RE: Name this Plane
w8,
what are the spec on the kiwi ?for some reason I thought it was a small plane
w8ye 11-28-2009 10:48 AM
RE: Name this Plane
http://www.wattflyer.com/forums/atta...mp;d=120113199
I think you are right. It had a 54" wing. A little big for a "40" and a little small for a "60"
http://www.wattflyer.com/forums/atta...p;d=1201131991
MetallicaJunkie 11-28-2009 06:24 PM
RE: Name this Plane
That definitely looks like the plane i have!!!!What a coincidence W8ye we both have the same Snoopy pilot/furure with the huge moustache
Gray Beard 11-28-2009 06:43 PM
RE: Name this Plane
W8 comes through again!!!!! Between you John and RainDave I figure you guys have seen and can remember any plane ever made!!! I can't remember ever seeing or taking notice of the KIWI??
safeTwire 11-28-2009 10:36 PM
RE: Name this Plane
1 Attachment(s)
OK...I'll stir the pot... Could it be a KwikFly?
w8ye 11-28-2009 11:27 PM
RE: Name this Plane
I have a Global ARF Kwik Fly with a wing like yours but the tail is different on mine
One thing with Kwik Fly's there are at least 4 different versions of them
MetallicaJunkie 11-29-2009 02:07 AM
RE: Name this Plane
ORIGINAL: safeTwire
wow that looks like mine too
whatiwork4 11-29-2009 08:26 AM
RE: Name this Plane
it would help to compare if you posted the wingspan,chord and length of your plane
OkadaKeisuke 11-29-2009 12:50 PM
RE: Name this Plane
Considering that a "Kiwi" is a flightless bird, could this plane have been named after Wisscassett airport(KIWI) here in Maine? Just a thought?
psuguru 11-29-2009 06:44 PM
RE: Name this Plane
ORIGINAL: w8ye
Close, but I don't think it's the Kiwi.
The Kiwi's rudder strake is longer and the trailing edge is slightlytapered not just at the tip. But the plane in question has straight wings. What's unusual is the elevator extending behing the rudder.
That rules out the Kik Fly and the Taurus
safeTwire 11-29-2009 08:01 PM
RE: Name this Plane
Is the rudder mounted? Or is that just the vertical fin? I cant really tell from the photo.
Hey MJ...Turn up the juice in the lava lamp so we can get more detail!:D
MetallicaJunkie 11-29-2009 09:40 PM
RE: Name this Plane
1 Attachment(s)
ORIGINAL: safeTwire
LOL ok i took a couple more pics to help settle this
ORIGINAL: whatiwork4
you are right....WS is 60" and lenghth of fuse from the top of the rudder to the point of prop hub is about 44 (not sure how to correctly measure a fuse)
safeTwire 11-29-2009 11:39 PM
RE: Name this Plane
Snoopy Rules!
Your plane looks like it will fly well. Thick airfoil for plenty of lift, clean lines for aerobatics. Good luck with it and Enjoy!
Kwigen 12-01-2009 06:00 PM
RE: Name this Plane
I don't know what it is but the wing looks like its a Goldberg Sr Falcon wing.
